RP23 question
[Closed] RP23 question
[#3472179]
My RP23 has functioned flawlessly for the last 2 years.
I've always been a set and forget - I don't play with sag or propedal beyond the initial installation.
I've noticed now that my sag increases everytime I use it.
I'm either endulging in too many festivities or this thing has a slow leak.
I'm not sure if temperature has anything to do with it either.
I've not heard of this before - do they leak?
How can I check before putting it in for an expensive service.
Its never been serviced at all with moderate usage but I did take it to mojo 3 months ago who tested it and said it was working fine.
Posted : 18/12/2011 9:04 am
Check the valve is screwed into the body tight and the removable core is tight (you will need a core remover, they are built into the caps on Slime bottles)
You may find air is leaking between the positive and negative chambers.
Posted : 18/12/2011 9:11 am
thanks will try
Posted : 18/12/2011 9:30 am
You can do an air seal service yourself, seal kits are available from mojo and there's how to vids on you tube, but as above..check the valve core first
Posted : 18/12/2011 9:57 am
You wonder why it's leaking but haven't serviced it in two years? 🙄
It's to be hoped you haven't wore the anodising away...these things need to be kept lubed.
Posted : 18/12/2011 10:01 am
It needs a proper service. End of story.
An aicam service/lube will freshen it up, but after 2 years it needs a full job doing. Try LoCo Tuning, they're better value than Mojo.
Posted : 18/12/2011 10:56 am
