juicy 3 leaking res...
[Closed] juicy 3 leaking reservoir bodge?
[#3472177]
Has anyone successfully repaired one using anything other than the diaphram supplied in the kit? I'm thinking of a piece of innertube cut to fit, not sure how it'll last being in contact with brake fluid.
Posted : 18/12/2011 8:59 am
Don't do it. There is some things you can Borge, brakes are not one of them. Avid do a leaver service kit.
I just replaced the piston seals and had the cap off. The screws have to be done up very tight on mine to stop leaks.
Posted : 18/12/2011 9:20 am
