RP23 Propedal quest...
[Closed] RP23 Propedal question?
[#797367]
Can someone tell me which way the blue lever is oriented when Propedal is On? I.e. in relation to the Schrader valve. Cos I'm pretty sure mine is the opposite to what it says on the Fox site.
Posted : 19/08/2009 12:04 pm
Nearest the valve when its on
Posted : 19/08/2009 12:05 pm
Yep, nearest the valve. Mine points towards the right when sitting on the bike.
Posted : 19/08/2009 12:06 pm
Thanks both
Posted : 19/08/2009 12:07 pm
Mine is the other way round. Propedal off when it points towards the valve but a friends GT Marathon (yes someone bought one) is the opposite.
Posted : 19/08/2009 12:44 pm
 ton
mine hangs to the right too................ 😉
Posted : 19/08/2009 12:46 pm
You should be able to feel a difference in the lever when moving it. You have to push pro pedal on until it clicks. When removing pro pedal you can just flick it and it automatically returns to a neutral position (pro pedal off)
Posted : 19/08/2009 12:47 pm
Ah that may explain it then
Posted : 19/08/2009 12:48 pm
