Rotors/adaptors que...
[Closed] Rotors/adaptors query - fairly 'urgent' answer required
[#5590650]
Hi - need quick answer to what is probably a dumbass question.
Bear with me:
I currently have a 203mm XT 6 bolt rotor up front (RS Revelation post mount using a 203mm caliper adaptor) on a DT Swiss centerlock hub using a DT Swiss adaptor. Out back I have a 185mm XTR centerlock rotor on an XT centerlock hub using a 185mm caliper adaptor.
I am buying a Hope 6 bolt rear wheel as my current rear needs replacing.
Can I use my front 203mm 6 bolt front rotor with the 203mm caliper adaptor on the back - then put the 185mm centerlock rotor on the front using the 185mm caliper adaptor?
In theory I should be able to - means the front rotor will be slightly (18mm) smaller than the back.
I need a quick 'yes you can do it' as picking up wheel after work!
Cheers 🙂
Posted : 10/10/2013 4:46 pm
I think when used at the rear calipers go up 20mm from front.
so a 203mm adapter for front would fit a 223mm rotor at the back?
Certainly used to be the case.
Posted : 10/10/2013 4:51 pm
Should be fine I'd have thought - it's the rotor size and caliper adaptor that should match.
Found out the hard way some Hope brakes are 183mm rather than 180. Well, it wasn't that hard just a really really annoying noise climbing out of the saddle
ting..ting...ting..ting
EDIT - oh hang on,didn't notice you were swapping ends .. I'm pretty sure when I cured said noise I bought a caliper adaptor front and rear specific - and CRC seems to back that up.
Posted : 10/10/2013 4:52 pm
Will the front adaptor even fit the rear? I would guess the front is a 203 post to post but the rear is more likely to be post calliper to IS frame mount adaptor I would have thought?
Posted : 10/10/2013 4:56 pm
Not sounding too promising...give me some hope someone! (no pun intended!)
Posted : 10/10/2013 5:08 pm
Is the rear brake mount post mount to post mount (like the front) or IS to post mount?
If PM2PM then you're fine, if IS then you'd need a different adapter for the front
Posted : 10/10/2013 5:13 pm
Not sure...I think I'll go home and have a fettle then take bike to the seller's house.
Arse - that's 2 journeys, not one 😕
Posted : 10/10/2013 5:25 pm
No it won't work.
I've just looked at an adaptor and it said 160 rear or 180 front , so there is a 20mm difference front to rear
Posted : 10/10/2013 5:31 pm
any luck?
Posted : 11/10/2013 4:11 pm
