Rotor Wear - when t...
[Closed] Rotor Wear - when to change?
[#1663940]
Hi All,
When is a disc rotor considered worn and in need of replacement? I have a set of Avid 160's used with BB7s that are about 2 years old. They have quite a bit of scoring and there is just noticable thinning of the material on the braking surface in comparison with the inboard edge outside of the sweep of the pads.
Any recommendations on this?
Thanks
Posted : 01/06/2010 8:08 pm
Was this question considered too stupid to warrant any replies???
Posted : 04/06/2010 12:33 pm
never. its a bit of metal. unless its so thin it looks like it might break then why worry?
I only changed the rotors used with my original mini's when there was a [u]considerable[/u] thinning of the braking track.
Posted : 04/06/2010 2:24 pm
OK thanks all for the replies
Posted : 04/06/2010 2:58 pm
Either my shimano or formula rotors had this printed on them - 1.2mm
Posted : 04/06/2010 3:00 pm
I change mine when the thinest part is approx. 70% of the original thickness. You probably didn't get many answers because not many people are able to accurately measure thier rotor thickness. so tend to just ignore the problem.
Posted : 04/06/2010 4:11 pm
I change mine when the thinest part is approx. 70% of the original thickness. You probably didn't get many answers because not many people are [s]able[/s][b]bothered[/b] to accurately measure thier rotor thickness. so tend to just ignore the problem.
fixed that for you 😉
Posted : 04/06/2010 4:18 pm
