Rohloff dropout hel...
[Closed] Rohloff dropout help. Where can I get one of these?
[#6894016]
I have a Pipedream Skookum.
It has adjustable dropouts:
[URL= http://i225.photobucket.com/albums/dd279/letmetalktomark/IMGP2942_zps8583636d.jp g" target="_blank">http://i225.photobucket.com/albums/dd279/letmetalktomark/IMGP2942_zps8583636d.jp g"/> [/IMG][/URL]
I have a Rohloff hub I plan to build up to use with the frame and a Monkeybone that would allow use of the current dropouts but ......
I know that you can get a Rohloff dropout that will fit but I can't find from where. I've previously looked at Paragon but they don't do one that fits 🙁
The dropout design is AFAIK the same as Kona but I've had no joy contacting them - I tried a while ago for a 142mm kit 🙁 🙁
Any thoughts?
Posted : 26/02/2015 9:40 pm
Sadly not.
The frame has two slots rather than one continuous slot that the dropouts above use.
Posted : 26/02/2015 10:13 pm
They look the same as the kona dropouts...
Posted : 26/02/2015 10:25 pm
Right, not everything that slides is PMV :).
Maybe the ones at framebuilding.com have the correct dimensions (bolt size, slot width, distance between holes)? It's worth asking, I suppose.
http://www.framebuilding.com/NEWPARTSPAGES/Forged%20Dropouts.htm
Posted : 26/02/2015 10:29 pm
Argh, they are all so close, but yet not right. The frame doesn't have a recess on the rear to accept a sliding strip so all of those above wouldn't fit 🙁
Posted : 26/02/2015 10:34 pm
So you're looking for a LH OEM dropout? Similar to the ones from Ceeway but without the protrusion for a slotted dropout?
Could always get the Ceeway one and machine off the protrusion, assuming the other dimensions match. If you like, post me up your existing LH dropout and I can see what I can do.
Posted : 26/02/2015 11:09 pm
I think it could be the Kona "type CC" dropout; unfortunately no Rohloff version available http://www.hibike.de/shop/product/p1f95cbd7034bc8174856e1ad78d59ea1/KONA-derailleur-hanger.html
(also on CRC http://www.chainreactioncycles.com/ro/en/kona-rear-derailleur-sliding-cc/rp-prod71905 )
The guys on this German forum have a thread dedicated to Kona Unit/Honzo, might be able to offer some suggestions.
http://www.mtb-news.de/forum/t/der-kona-unit-honzo-29er-stahl-thread.552984/page-54
Posted : 26/02/2015 11:12 pm
I'd stick with the Monkeybone and standard dropouts. Looks neater (and is the zero-effort option)
Posted : 26/02/2015 11:36 pm
You should be able to get them from Pipedream - I did for my Sirius.
Posted : 27/02/2015 10:22 am
