HI.
I made a complete maintenance of my RS Yari cleaning it and changing oils.
No o-rings changes as I found them ok.
Before the maintenance I obtained the 30% sag with 70-75 PSI.
Now I have to increase the pressure at 85 PSI.
Is there a problem?
Can you explaine the reason?
Thanks
Posted : 20/06/2017 3:47 am
Shock pump accuracy? Sag measure accuracy or you might have a slightly different oil level somewhere in a air leg. Set by sag rather than pressure generally etc.
Posted : 20/06/2017 3:52 am
