So can anyone help with this.. i have 2010 rockshox revelation dual air uturn forks. the u turn on my rockshox is stuck. i can twist it down a bit but won't allow me to increase travel to 150. its max is 135. is it a problem with the uturn adjuster knob and can it be fixed easily and how without taking all the fork apart.. or is it something else that is stopping the travel from going all the way to 150mm? Any advise would be very welcome.. other than that the fork works very well. no leaks, hold air etc...
Since it's causing a problem at a certain height I don't think it's just the dial being gummed up (which is the cause of most u-turn issues tbh). What's the service history like?
Are they the Teams? Quite a simple design if so, I know forks are a bit more intimidating than most diy spannering but there's not too much to fear in opening these up for a look.
cheers for the info... yea they r the teams... might just have to open them up and see what is going on... can you take the top adjuster off anyway without having to take all the air out or take it all apart to see if that is the problem? i have found the manual online and doesn't look to hard but says to take the bottom legs off ager taking all the air out.. they work fine at 135mm so slightly worried that taking them apart may cause more of a problem... service history is that they haven't been taken apart for over a year but i don't get to ride that often or hard... like once or twice a month...
