Rockshox super delu...
Rockshox super delux ultimate LSC dial
[#12939473]
HI
The LSC dial on my shock seems to turn endlessly in either direction
I think there is a build up resistance as it gets to where I think fully closed is but it keeps turning.
Which direction should i turn to try and get to an end/start point?
Is this a known issue?
Its not the latest model but the one before
James
Posted : 23/08/2023 8:16 pm
The top one? I know in ours it's 10-11 clicks depending on which wheel we're running. That's from fully clockwise to going anti clockwise when sitting on bike.
But not sure how many is the max, but I can check if you need
Posted : 23/08/2023 8:46 pm
Thanks weeksy, based on your 11 click range ive taken it to fully open (anti-clockwise) it does actually come to a stop in that direction, just not the other. I normally set clicks from fully closed which wont work so ill just have to go the other way
cheers
James
Posted : 24/08/2023 1:24 pm
FlagrantBass reacted
