there are specialized oe and should have 90mm travel,but only showing 60mm of fork leg,ie they dont rest at 90mm,any ideas anyone please
Posted : 06/05/2012 10:52 pm
Try letting out all the negative air. See if that brings the travel back up.
Posted : 06/05/2012 10:56 pm
thanks mtbmatt,thats all it was
Posted : 09/05/2012 10:52 pm
It will be horrible running them without negative air, but that is usually the problem when people say they have "lost" travel.
I find it best to run 10psi [u]less[/u] in the negative compared to the positive. You may loose some travel, but only 5-10mm.
Posted : 11/05/2012 10:22 pm
