Rockshox reverb and...
[Closed] Rockshox reverb and specialized internal routing
Interested to know if anyone is running a rockshox reverb through a stumpjumper internal routing.
I've just got a new stumpjumper evo frame and the routing is for a 4mm cable outer (like a specialized post) not a 5mm hose like on the reverb.
If so how did you get around this?
Tempted to get a ks lev.
Posted : 23/05/2014 8:47 pm
I've filed mine slightly out to 5mm after reading about others doing it on mtbr etc.
Posted : 23/05/2014 10:17 pm
Ok thanks. It's just the hole that's too small then? I'm assuming there's a lining of some sort inside the tube.
Posted : 23/05/2014 11:52 pm
Yeah it is just the hole, it go's back a fair way then there is some sort of guide in the top tube but it fits through that fine, and the hole above the shock is plenty big enough.
Posted : 24/05/2014 5:39 am
That's brilliant. Thanks.
Posted : 24/05/2014 9:41 am
