I have a 2010 RockShox Recon SL Solo Air with the lockout knob on the fork. My problem is that the lockout knob won't stay in the lockout position and would just spring back open. The forks would lockout but I have to hold the knob in the lockout position.
Any thoughts on what the problem would be or how to fix this?
Thanks!
Posted : 14/03/2012 8:32 am
Have you taken off or not fitted the PopLoc? I think the RL version uses the PopLoc. If you want to use it without this then you have to remove a spring from inside the damper unit.
Posted : 14/03/2012 9:52 am
ah ok. It's not fitted with the PopLoc. I just installed the lockout knob and I thought it was enough.
Thanks!
Posted : 14/03/2012 11:41 am
