Rockshox Reba Race ...
[Closed] Rockshox Reba Race - Convert to Poploc/Pushloc
Advice please if I wanted to convert my Reba Race to Pop/pushloc do I need to do anymore to than fit the lever cable and change the top cap on the right fork leg?
thanks
Posted : 22/12/2009 8:56 am
The Motion Control unit in the top of the leg needs to have a return spring in it, or the lever won't spring back to open it again. This will probably need a new M/C fitting, which ain't cheap....
Posted : 22/12/2009 9:00 am
fingers, if you want to do a swap I've got a motion control oplock cartridge which I don't use, and would rather have the fork top lock-out. it's a simple job to remove the cartridge and swap. I don't have the remote though. drop me an email if you're interested.
Posted : 22/12/2009 9:49 am
Fingers - I nearly suggested that as your best bet. Me? I'd rip his hand off if I were you, it'll save you a huge amount of money. 🙂
Posted : 22/12/2009 9:51 am
a moco unit is about 40quid....easy to change!!!
Any bikeshop that has a fishers account should be able to get you one!
26mm socket...undo old one....insert new one...26mm socket....tighten new one
Stand back and admire handy work that would have cost a fortune @ TF
Posted : 22/12/2009 10:01 am
Eh, where do you get the remote from? (I've seen them, but not cheap) I also have the gubbins but no remote...
Posted : 22/12/2009 10:29 am
there's one in the classifieds at the moment, they do come up,je james have them for £30.
Posted : 22/12/2009 10:32 am
