Rockshox Pike Top O...
[Closed] Rockshox Pike Top Out/Clunk
[#6880469]
Suffering from the dreaded Pike Clunk/Top Out.
Only started when i changed the air spring from 150 to 160mm. The forks work flawlessly, but have 10mm of dead band before the damping kicks in and play when there is no weight on the fork.
googled it and it seems that the Bypass Slot can become full of sram butter stuff when you change the air spring meaning that the positive and negative air springs don't balance.
Ive tried all the tricks of letting air out, putting cable ties down the sides etc and none seem to have done the job.
Anyone had this before?
Where is the bypass slot? Ive checked tech docs and on my old air spring and can't spot it so must be on the stanction somewhere.
Thanks
Posted : 21/02/2015 11:13 pm
Page 1 half way down bud.
http://singletrackworld.com/forum/topic/2014-rockshox-pike-problemsadvice
Posted : 21/02/2015 11:44 pm
Cheers Rob 🙂
Posted : 21/02/2015 11:59 pm
Any more thoughts on this anyone?
Posted : 23/02/2015 8:55 pm
My pikes lost all their damping in their first few mm of travel, which gradually increased to the first inch. An o-ring in the cartridge had started weeping and had let out a few ml of fluid. O ring replaced and cartridge re-bled (under warranty) and all working perfectly now.
Posted : 23/02/2015 9:18 pm
Mine now clunk on top out since I refitted the 150mm air spring. Not worried about though as you don't notice it riding and performance isn't effected. They did the same when I first shortened them with the 140 air spring, but knocking went after a few hard rides. I'm confident it's just the slot for balancing chambers blocked with the grease I put on damper quad seals.
Posted : 23/02/2015 9:31 pm
Chipbutty, Did you change the air pressure at all while riding them "hard", or did you leave them alone and just ride them as normal.
Posted : 23/02/2015 11:13 pm
Just rode as normal
Posted : 25/02/2015 11:47 pm
