Rock Shox Revelatio...
[Closed] Rock Shox Revelation - can't get along with them
if it has no small bump sensitivity try all compression damping off - zero - floodgate open
Posted : 13/12/2010 4:17 pm
I must still not have enough -ve air pressure because I was trying to get all the air in quickly and detach the pump before I lost all the pressure!
as bigdon says this should be fine - the hiss you hear should just be the pressurised air from the pump tube escaping. I would avoid going above the +ve pressure to start with - start with equal or slightly less. My -ve valve does leak oil and air over a while though.
oooohhhhhhhh I'm telling!!!
she's worse than me actually! but we are soooo losing our deposit on that flat....
Posted : 13/12/2010 4:22 pm
Just wondering if the tuning advice would given here would be similar for 2010 Sid Teams?
Just got some and thought the instructions to be lacking...
Posted : 13/12/2010 5:07 pm
bigdonx - Member
You shouldn't lose air with the pump attached unless there is a fault of some sort - yes if you detach/reattach the pump you will get a drop from what it was before - but should not keep losing pressure.
Exactly.
Important question - are you losing pressure over time while the pump is attached?
If you are then there is a problem that might explain the lack of small bump sensitivity!
Oh, and dekerf, yes, SIDs are essentially the same.
Posted : 13/12/2010 5:36 pm
Page 2 / 2
