Rock n roll extreme...
[Closed] Rock n roll extreme - will it work if i .....
[#721498]
clean and dry teh chain then immerse/soak the chain in it for an hour or so and then let drip dry?
Posted : 20/07/2009 2:28 pm
No need to soak it just apply it liberally, spin the pedals round a bit & then wipe off as much as you can
Posted : 20/07/2009 2:30 pm
i know about the application when fitted to the bike. Just wondred if it would be more prudent to soak it, less waste
Posted : 20/07/2009 2:41 pm
Can't see what difference it'll make - give it a try & report back any benefits
Posted : 20/07/2009 2:44 pm
i have considered the same thing and would assume that it would guarantee better, more penetrative, coverage. so would have thought it would be a good idea, if one could be bothered. i also thought that for this reason it might be an idea to fill a chain cleaner with it?
Posted : 20/07/2009 2:48 pm
Applying whilst turning pedals helps the lube work between the rollers as they get moved over the sprockets......
Posted : 20/07/2009 2:49 pm
I always wondered about soaking my chain in lube also. Lube prices are extortionate if people are honest, so as rr says less waste?
Didn't someone like rohloff use to make a tin of wax lube that was melted on the stove before you dunked your chain in it?
Posted : 20/07/2009 8:23 pm
Loads of things like that marketed at motorbike riders
TJ is almost evangelical about Putoline's offering
Posted : 20/07/2009 8:42 pm
