Hi,
I'm in the process of swapping over my front brakes (Tiagra 4600) and i've found that the 'caliper fixing nut' is not long enough.
The frame is a cube GTC with their own CSL race forks, which are tapered and a lot fatter than my old ones.
I've got a 38mm nut but this doesnt seem to be long enough and I can't find any longer ones out there??
Any ideas ๐
Thanks
you are fitting a front caliper and not a rear one?
You can get longer nuts, some forks come with the required nuts
38 mm already sounds pretty long
Yeah I thought I may be fitting the wrong one but i'm pretty sure i'm not as the rear one has a shorter screw bit on it.
That's my own measurement of what I have, 38mm - it's still about 20mm short though i reckon. I'm wondering if i'm missing something here!!
the head of the bolt/nut thing will normally go into the recess in the back of the fork - it doesn't need to be as long as the fork is thick?
Hi I have the exact same issue, can Nyone tell me the required length of nut please?
Been there, done it and fixed with a 50mm nut.
You need to have a word with your lbs. Mine cost me some biccies! They are often a workshop spare (left over from retail packs with aftermarket brakes or from fork fittings) but I couldn't find a "retail" pack/product for one of these longer nuts anywhere online.
A lot of Campag brakes come with a variety of lengths of bolts. Maybe someone with a Campag brake set can give you a longer bolt?
