Road discs - A bit ...
[Closed] Road discs - A bit of a random musing....
At the lower end of the price scale, the STIs are close to the most expensive part on a road bike, frame and wheels included. Your upgrade path needs to leave the levers alone otherwise you might as well change the whole bike. Pomp/Kaffenback, Tripster and RoadRat, any others been successful offering either/or?
Posted : 01/09/2013 9:46 pm
isn't a solution to any relevant problem...
Here's one.
Having badly scored a front rim after some tiny metal road debris got stuck to my brake pad in the damp I'm all for discs.
See also, stronger lighter rims, better wet weather braking, less wheel wobble worries, etc.
Carbon rims seem to be getting more and more popular but braking performance is not great . Disc brakes solve that one at a stroke . You can save weight at the rim where it affects performance most , you can make the rim more aerodynamic . Anybody with MTB disc brakes will know that apart from outright power and consistant performance the other advantage is that you can brake with the wheel just not quite locking up , you just don't get the same feedback with road caliper brakes especially with carbon rims . People spend thousands of pounds on road wheels , disc brakes will mean they get to wear out slower .
Posted : 01/09/2013 9:48 pm
 pdw
I can easily lock and slide my 23s down a dry road on budget dual pivots
Really? On a dry road, you'll go over the bars before the front wheel starts to slide.
Posted : 01/09/2013 9:49 pm
But it still takes 2 or 3 years to wear out a road rim. Cyclocross will trash them in a winter, but the longevity in road riding is not as pressing an issue as it seems.
I suspect that as with wheel size, we will be led up the garden path by manufacturers who have invested in this, but I also suspect that the timescale required for the change in attitude will prove a problem.
Posted : 01/09/2013 9:51 pm
I already run discs on my commuter/trainer.
I currently run a Giant TCR Advanced as my good roadie but my next carbon roadie will have discs, which I'll buy/build over the winter. People can bleat on about rim brakes being fine - you can keep them. I'm going discs.
Posted : 01/09/2013 9:52 pm
, no, it doesn't.
How?
Yes, you do.
Which means people will buy fewer wheels, which is not a good thing for wheel makers.
Posted : 01/09/2013 9:54 pm
 mrmo
Now, one often overlooked advantage of discs is that the rim can be built to just be a rim, not a braking surface AND a rim. As such, you can theoretically, build a better, lighter, more aero rim. Which is a win.
not really though, brake tracks are almost an afterthought on carbon rims anyway, so yes you might save a bit of weight but a 50mm deep rim still has to have enough carbon to work.
Where disks make sense is on fast commuters, and i would wonder if the correct answer is drum brakes not discs?
Dynamo on the front, drum brakes back, disk front. (only because you can't have everything in the front hub, or have a dynamo in the bottom bracket?) maybe a hub gear on the back, belt drive etc.
The reality is that my next road bike will have discs, my next mtb will probably be 650b. This is nothing to do with what i want, but what will be available. When will i change my bikes? not for the foreseeable, they both work. End of the day, bikes don't really matter, if your unfit your unfit, legs matter more than any a bike.
Posted : 01/09/2013 9:59 pm
they might buy more expensive wheelsets less often, which would be okay ouldn't it ? (and I suspect a bigger markup ?)
Posted : 01/09/2013 10:00 pm
 mrmo
and the biggest gripe i have with discs, they rub, they ting, they are never quiet, changing the wheel is always a faff! so much other crap going on with the mtb i don't care, but the road bike. It is almost silent, I run a chorus rear hub and the clicking on that is loud enough thankyou very much. Would never use hope hubs on the road bike because they are far to noisy even though i use them on the mtb without issue.
Posted : 01/09/2013 10:03 pm
This argument was had when disc brakes first appeared on MTBs though. Maybe not quite as prevalent since it was early days of the internet forum but who remembers all the pages of letters to MBUK saying:
7-speed is fine, 8-speed will just clog up with mud
then later:
8-speed is fine, 9-speed will just clog up and the chains are narrower so they'll all break...
And:
cantis stop me just fine, V-brakes are just a fad
followed a few years later by
V-brakes stop me just fine, discs are heavy/complex/just a fad/will need bleeding every week.
Exactly the same here.
To be honest I suspect the main reason behind the disc brake thing on road bikes is that the manufacturers are waiting to see which brake system takes off (is it Di2 + hydro, SRAM hydro...?) and there simply not being enough disc brake stock to kit out everything at the moment.
There's absolutely no need for them, that's why they've never been pushed.
If your road brakes are rubbish, get some better pads or calipers. Job done. I've never felt underbraked on a decent road bike. Disks are for muddy conditions or places where you brake a lot.
Posted : 01/09/2013 10:05 pm
crikey - Member
, no, it doesn't.
How?
Yes, you do.
Posted 4 minutes ago # Report-Post
Well in my world losing rotating weight is better than losing static weight , if you are really pedantic the tyre is further from the rim therefore will have the most effect .
You can build more aerodynamic rims because you don't have to build in a braking surface .
You are obviously a riding god with unbelievable skills , for the rest of us mere mortals discs have more feedback .
Since disc brakes became the norm on MTBs wheel manufacturers haven't been closing down in droves , perhaps the industry sometimes does things to give riders a benefit not just the balance sheet .
How often do you brake on a road ride or race? I think I've ridden races where I haven't braked at all, bit different from mtbing.
Other issue for pros is speed of wheel change which is worse with discs.
I can see hydraulics making sense for commuting but cable operated are sh*t.
Posted : 01/09/2013 10:06 pm
 mrmo
then later:
and how many people UPGRADE the bike, how many just buy a new bike and get what they are given?
Posted : 01/09/2013 10:07 pm
I keep checking the Upgrade bikes website but they're still showing the Hy-Rd's as Back Order. I'll be putting them on my Whyte Saxon Cross as soon as they're available, the current BB7's are OK but as said above a bit of a fiddle I could do without. Next years Saxon Cross is spec'd with Hy-Rd's as standard.
And when will people understand that good brakes are about modulation not power. 🙄
Posted : 01/09/2013 10:08 pm
 mrmo
but you can't, look at a 50mm rim now make it more aerodynamic, the rim is still there, the size is the same, the tyre require the same fitment...
Rigida went pop... and what has happened to Sun, Araya, weinmann etc still around granted but a few changes.
decent rim brakes are better than discs, when set up well and not covered in crap, so mtb, cx perfect market, road....
Posted : 01/09/2013 10:13 pm
 mrmo
and the Centaur brakes i have on the road bike are fine in that regard. decent pads, huge 622mm rotor, great for heat dissipation, no risk of aluminium cored disc melting.
Posted : 01/09/2013 10:15 pm
If you search out the considered opinion on this, rotating weight is the same as weight. It doesn't matter if it spins, it's still weight so it's ability to rotate doesn't matter.
No.
If you make an aero wheel, it will have a flat surface that brakes can act on.
Yes, I am.
You're so far out in the Elephant grass with this one, that you'll never ride home... It's an industry, they're not your friends.
Example: Shimano HG cassettes; they realised that people were turning the single cassette sprockets around to extend the life of the drive chain, so made them into UG sprockets and fixed them onto spiders...
Posted : 01/09/2013 10:16 pm
Hands up those who have actually ridden road bikes with disc brakes and would willingly give them up?
as dibbs said, its modulation and brake lever feel that makes the difference with hydraulic (and on TT bikes, the ability to have tight cable routing, although as yet I've not seen a disc TT bike, only the magura RS8s), as well as wet weather performance.
I've ridden all the main systems on the market (calliper, BB7, TRP hydro, SRAM hydro, shimano hydro) and given that I don't race, if i were to buy a new road bike, it'd have discs.
they have far better modulation, complete 1 finger braking whatever the conditions and however hard you have to brake. they allow you to brake far later into corners, which means you go faster. its the control of the braking which is so much better.
i can't see the UCI allowing them in racing any time soon though, thanks to safety fears. they'll be the reserve of grand fondo/sportive riders imo. nowt wrong with that though.
at the end of the day, it's just like wheel sizes. if you don't like it, don't buy it... it's just a bike at the end of the day and not worth getting knickers in a twist about.
Posted : 01/09/2013 10:17 pm
 tang
[img][url= http://farm8.staticflickr.com/7429/9314529677_51da535a27.jp g" target="_blank">http://farm8.staticflickr.com/7429/9314529677_51da535a27.jp g"/> [/img][/url] [url= http://www.flickr.com/photos/56594563@N07/9314529677/ ]Hyrd[/url] by [url= http://www.flickr.com/people/56594563@N07/ ]tangwyn[/url], on Flickr[/img]
Here's mine. They are quite well built, if a little bulky(no weight penalty over bb7). Work a treat with the ultegra levers I have, very easy to set up, modulate nicely. I did one long road ride in the rain on cow shitty lanes. The rest has been dry! Perfect for your cx/winter trainer/tourer I reckon. Off road, so nice to be on the hoods and get the power with ease.
Posted : 01/09/2013 10:21 pm
The power argument is a red herring - road caliper brakes are (mostly) more than good enough but it's not all about power.
Better modulation, consistent braking no matter what the weather, how cold your hands are, how tired you are, how laden the bike is.
The ability to run full internal hose routing, better integration, tight turns.
Allowing the wheel to be light and aero without having to have a braking surface as well.
(same with electronic gears to be honest; regular mechanical shifting is pretty much perfect but the actual gear shifting is a secondary function of how good they are for all the other reasons).
Posted : 01/09/2013 10:22 pm
My Tripster ATR is specced with Tektro Lyra cable operated disc brakes and they are pretty damn astounding for a cable operated system, light, excellent modulation and i can do small rolling stoppies time and time again, no brake judder or fork/frame flutter thanks to the well thought out Kinesis frame design and whether i use one finger braking from the hoods or decide to grab a handful from the drops i can expect the same braking response time and time again.
Disc brakes just make sense but there's no point in trying to convert existing hydro systems to work from enlarged hoods/reservoirs as master cylinders, when the major manufacturers pull their finger out and start designing fully integrated systems from the calliper through to master cylinder then the UCI will have to acquiesce on their non approval stance.
Posted : 01/09/2013 10:26 pm
Meh.
We shall see; I suspect that the market will be driven by what the big manufacturers think we should have, and by how much financial clout is brought to bear on the UCI rather than by anything else.
I've got 6 pairs of rim brake wheels to get through yet...
Posted : 01/09/2013 10:28 pm
 mrmo
This is the UCI your talking about.
Posted : 01/09/2013 10:29 pm
Those Hyrd things are bloody ugly. Can't see the point of them just like all cable actuated disc brakes.
The benefits of hydraulic disc brakes however are plain to see and perfect for year round commuting. Little maintenance which is essential when you arrive home in the dark and leave early the following morning, more reliable braking on wet descents approaching busy main roads, no wear on the rims and the cold hands won't have to work so hard during the freezing wet weather we get.
Riding over 100 miles a week, every week, all year what ever the weather I need these for my commute. Couple of years back I broke a weakened rim riding over a pot hole, in the dark when it was chucking it down. The rim walls had become thin from braking in the rain and grit and just split.
I've been waiting for this technology for years and now they exist I will tolerate my rim brakes for one more winter then make the move when the price is more reasonable and the tech is more established.
I'm sure a lot of the people who don't see the need in disk brakes don't use their bikes as a utilitarian means of transport more a pleasure device.
Posted : 01/09/2013 10:54 pm
Keeping hands firmly down 😀
Posted : 01/09/2013 11:25 pm
Don't need them. Ride my bike everyday in all weathers. Reflexes and sense are part of road braking. Off road disks are great for avoiding trees and small rabbits.
Posted : 02/09/2013 12:00 am
Mine are staying and more.
The day I can afford hydraulic/electric set ups I'll have them.
In fact if I had to have one I would prefer them on my road bike to the mountain bike.
Posted : 02/09/2013 6:59 am
Take it that, having formed such a strong opinion of them birdage, you've tried a few out over a decent period of time?
What didn't you like about them?
Posted : 02/09/2013 7:34 am
Of course not having to build in a braking surface will help with optimising aerodynamics at the rim. All of a sudden you're not constrained to having two surfaces that have to be paralell and about a quarter of an inch wide - without that you can contour the rim in that area to improve aerodynamics. Similarly you don't have to make that area thicker than it needs to be to build in a wear allowance and extra strength to resist braking forces in an already highly stressed part of the rim. Wasn't there a problem with carbon clinchers failing at the rim not so long ago?
Its a marginal gain, but that's all you're looking at on road bikes - there are no more step changes to come, unless you get radical.
Posted : 02/09/2013 9:02 am
I am going to put my penneth in here!
I have now put around 800 miles on to a C59-disc.
Frankly if you have'nt ridden one, you can't comment! They are chalk and cheese.
Generally people are right, road brakes are very good, but the control over power application in the dry is significantly better. You simply don't have the lag that exists on rim brakes, where you make contact, then pull a little harder to start to get some braking.
In the wet, there is no comparison, yes rim brakes will stop you, but no where near as efficiently, or with the same level of control as discs.
They are quiter than rim brakes, none of that nasty grinding noise whislt the brake cleans the rim, then dries it, then starts to do some braking.
In short i have so far found no down sides to them, and considering they are first generation road hydraulic they are excellent.
It is like electronic shifting, you don't need it , but when you have it you realize they do make a worthwhile difference.
SNIFF
Posted : 02/09/2013 11:24 am
Just bought my second CX bike to commute with. It has BB5's which are by no means perfect to set up but a country mile ahead of the rim brakes they replaced, which I'm sure will be a massive improvement when the winter comes.
The difference for me is like night and day, especially knowing I'm not grinding away my rims with winter salt and crap from the roads, I'd much rather change a disc than have a wheel rebuilt.
Think I'll be treating myself to a Hope V twin setup for Christmas.
Posted : 02/09/2013 11:34 am
I was far from convinced about road discs as per the fairly usual comments in this thread - no need, calipers work fine, etc.
Then I got my new CX frame which is disc only. I also use my cx bike with proper road tyres as a winter/crap weather trainer and actually as the new frame is fairly spangly, it's actually no slower than my 'proper' road bike.
The surprise for me was just how much better the control of braking is on the CX. With calipers there's plenty of power but I've often found that panic braking results in a short lockup followed by modulating it so slow down effectively. I've not locked up once on the disc'd CX.
In the wet, it's night and day though - I feel much better in control - largely down to the better feel/control and no delay in the brakes starting to work as they wipe water off the rim.
I've even been considering whether it'd be worth fitting a disc fork to my 'proper' road bike...
Posted : 02/09/2013 11:43 am
How often are people changing worn out rims? I've got wheels from the 90s still on original rims... my winter trainers go through a front rim every, what, 3 or 4 seasons? 60€ for a DT rr1.1 and a couple of hours to change it. Can't see the advantage of discs for that. They also look gopping (subjective) and I can't comment on this mythical power and 'modulation' as I haven't tried them, but it sounds suspiciously like a bike manufacturer trying to sell me lateral stiffness yet vertical compliance 🙄
However, they would make changing between training & race wheels easier, no pad change required, for the single-biked among us at least.
Posted : 02/09/2013 11:44 am
When I was training a lot, a rim used to last 12-18 months before it'd go BANG (literally...)
But that's irrelevant for me and not a real reason to fit discs unless you have very expensive rims.
Posted : 02/09/2013 11:47 am
This, lots. I don't use discs on my road bike but do on my "knocking about" bike which is a CX bike with road tyres. I miss the brakes every time I ride the road bike.
Posted : 02/09/2013 11:48 am
[i]Hands up those who have actually ridden road bikes with disc brakes and would willingly give them up? [/i]
Never. I've ridden plenty of disked cross bikes on the roads though, loads and loads of them which is pretty much the same thing and I prefer rim brakes on those.
Posted : 02/09/2013 11:51 am
Well there's always one 🙂
How so?
Posted : 02/09/2013 11:54 am
I did some cycling in the Alps this summer: I kid you not, every single hairpin on Alpe d'Huez had someone repairing a puncture, and as far as I could see, all of them were using carbon rims.
Anyway, the retro-grouch nichemongers grumbling about discs probably also griped about STI shifters and clipless pedals. I'll have Di2 and discs on my next bike, please.
Posted : 02/09/2013 12:01 pm
bob_summers - Member
my 'new' wheels, have now down 3 summers in the peak district, they're noticeably worn.
i'd rather not wait until they fail thanks, i'll give them another 2 seasons i guess? - and that'll mean a £200 rebuild*. that doesn't sound so bad for 5 years use, but i'd rather replace 2x £15 discs.
(*and while i'm doing it, i might as well replace the lovely, but cheap shimano hubs, it just seems such a waste of components that would otherwise last decades)
my 'winter' bike has cable discs (BB5's), they're ace, they don't drag, and they're easier to set up than the calipers on my nice bike.
I'm now in the completely daft situation where my nice bike will be getting cheap wheels as they'll only wear out in a few years, and my 'hack' bike will be getting nicer wheels...
or worse, when my the wheels on my nice bike need replacing, i'll just stop using the bike, and use the winter/hack/commuter all year round.
Posted : 02/09/2013 12:11 pm
Are hydraulic discs supposed to give better modulation than calipers?
I'd never noticed.
But then I have Avid Elixirs. 🙁
Posted : 02/09/2013 12:22 pm
A lot of people suggesting they are "not needed".
Not really an argument when your riding a flash bike. You don't need all the bells and whistles but its nice to have em.
personally I wont be fussed what brakes my next road bike has, which ever is the best ride and all round package.
Posted : 02/09/2013 12:38 pm
Back in the day I used to get about 2 years. That was based on about 6000 miles a year. Normally changed when the sidewall split.
Posted : 02/09/2013 12:54 pm
Page 2 / 3
