Road chainset on mt...
[Closed] Road chainset on mtb?
[#1019461]
After reading the article on Peaty running a SRAM road cassette on his DH steed (issue 53/p45), it got me wondering about the benefits of using road kit on mtb's. My brand new inbred frame should be arriving on monday which I want to build up as a winter training bike and summer speedy machine, and so a bit of experimentation might be in order.
Does/has anyone run a road chainset on their mtb through winter? Does it make much difference to using an mtb one?
Posted : 07/11/2009 11:41 am
apart from the BCD there is little difference, why would you run it in winter?
Posted : 07/11/2009 11:44 am
 fbk
Aren't road BBs wider?
Posted : 07/11/2009 11:46 am
Because we need about 3" more clearance for our back tyres you might find the crank hits the (very splayed) chainstay unless you have a really wide BB spindle. Then the chainline would be out.
Posted : 07/11/2009 11:53 am
Not intending on specifically running it in winter. But the first ride will be in the winter, so I wondered whether the road kit is any worse at dealing with Ridgeway chalk and Swinley sand.
Posted : 07/11/2009 12:05 pm
 jonk
It will be ok i'd run a triple 32-42-52 or something like that and your frame will have to be 68mm unless its no a ht2 or similar chainset.
Posted : 07/11/2009 12:10 pm
Looking at the amount of metal on my Ultegra crank arms, I would not be wanting to do anything extreme unless you are a featherweight.
Posted : 07/11/2009 12:30 pm
They'll be plenty strong enough, but there's just no point frankly, particularly if you're using it off road it's just a bit daft.
If you've got a 68mm shell it may be possible, but do you really need a 52t front ring? And you won't be able to go smaller than a 32.
Nico Vouilloz ran a Dura Ace 7800 chainset on his 4X bike with a carbon bash guard, that looked good.
Posted : 07/11/2009 5:06 pm
