Rode out with mates today..and blimey had 6 yes 6 punctures on a 40 mile loop.
Wheels fine
New tubes each time, correct tube size
Pressures - 110 - 110
5 to rear 1 to front
No thorns/ flints found each time
Most of the holes appear to be more of a slit rather than a puncture, and I'd say 4 out of the 6 are all on the inside of the tube.
Bad luck ??
I doubt it but really cannot find a cause.
try the rim tape, it buggered me up last week. 3 punctures, all at the bottom of the tube.
A spoke hole was showing through.
Sound like pinch flats or from a spoke protruding in to the rim, but then they would all be in the same location.
Take the tyre off, turn it inside out and with a good light, examine it all the way round.
I had 5 punctures in a week last year; it was a piece of wire stuck in the tyre that only caused an issue after an hour or so of riding.
Cheers chaps...the bike is currently unlovingly dumped in the back of the car...like a naughty child..
Will check the rim tape and tyre theories tomorrow.
What a frustrating ride!!
I had something similar on a road bike a while back, the rim tape was off center, exposing the sharp edge of a spoke hole.
I've had the same with almost invisibly small shards of glass before. In at an angle so the point only becomes exposed when the tyre flexes under impact. They were a complete pisser to find, I basically ran my fingers over every cm of the inner and outer of the tyre with it flexed in all sorts of ways. Still took two or three runs before I found them all. I now try to avoid riding near breakers' yards.
Next time it happens, line up the puncture site with the wheel/tyre and find out exactly what caused it. There will be something at that point that is responsible. From what you've described, I would go with the rim tape/rim bed theory.
i'm more impressed u carry 6 tubes with you on a run
although, i once did the black descent at GT from the mast and managed to get 17 holes in my tube at once. didn't patch that one up
Run a thin tissue around the inside of the tyre. It'll often catch on whatever sharp object is stuck in the tyre, leaving a little thread of tissue.
If there's no protruding spoke end on the inside or a piece of flint/glass/thorn embedded in the casing, you could be trapping the tube with the tyre bead when you're installing it. Check that you're not pinching it when you're seating the tyre (especially if you're using tyre levers) and check the bead/rim interface for trapped inner tube before inflation.
i had that once on my road bike... looked inside rim and there was thorn spikes lol..
