Road bike - why doe...
[Closed] Road bike - why does it hurt so much?
I bought a Planet-X road bike about six months ago and hardly ride it at all, for some reason it seems to be the most uncomfortable bike I've ever owned 🙁
After about 45 mins my hands go numb, then my neck starts aching and finally my back starts aching. I can't manage more than about 90 mins before I have to take a break. It must be something about the riding position but I can't work out what.
The frame is the correct size for my height (6ft1, large frame, 100mm stem) and I've played around raising the bars, moving the saddle forward and fitting a different set of bars but to no avail.
Anyone got any suggestions for things to try? I don't seem to have this problem with mtbs but then I guess I move around a lot more on them, I keep reading accounts of people enjoying long road rides and I'm getting jealous!
Posted : 27/09/2010 1:22 pm
Roadies enjoy the pain. It's their culture.
Posted : 27/09/2010 1:23 pm
 hels
Get a proper bike fitting done. Cost £30 when I had it done a few years ago, but thats way cheaper than physio.
I have just cycled 310 miles along the French Riviera in 3 and a half days on a road bike and confirm they are the plaything of the devil himself. Numb hands, numb finger and a bit of Achilles pain for my trouble....Fast they may be but god are they dull.....
Posted : 27/09/2010 1:26 pm
Hmmmm, bike fittings, always seems like a bit of a contentious subject; different methodologies, lots of folklore etc..
As you say you move more on a mountain bike.
Take the peak off your helmet - holding your head up at that angle is hard so look up more rather than holding your head up.
On a mountain bike you will find most people who ride in groups take a small break at the top of each climb / singletrack etc. this is much more than you would do on a road bike.
Just take some time to get used to riding it and let yourself have those breaks initially.
Move your hands around on the bars and change position lots.
HTH
Posted : 27/09/2010 1:27 pm
have you ever been comfy on a road bike ? - is this specific to that bike, or just new to roadie posture
I don't ride my road bike for more than about 90m-2hr at a stretch. Reckon I'd get sore if I did. On the drops, in particular, is quite a stretch for me
Posted : 27/09/2010 1:28 pm
Ive been a roadie for 3y after many more on MTBs
My experience is just like yours
It was hell and I wondered how anyone could enjoy it
My prob was I had biased the riding position to be "MTB like" if you know what I mean
Arse and weight as far back as poss
Muchos tinkering and a 120mm stem has cured it
3y ago - max ride 30 mins
Yesterday 110km with no bad back 🙂
Keep at it
Fit is everything
Numb hands suggests that you're putting too much weight on your hands, try to support your weight more with your back if that makes sense?
Posted : 27/09/2010 1:29 pm
whilst i agree they know better than you.
best £60 i spent.
where are you based? i know a very good bike fit in southampton.
as for hands try some better bar tape; a lot of bikes ship with cheap stuff.
also could be core strength.
Get a proper fitting from a good roadie shop.
Or failing that at least seek some advice from someone who knows about such things (LBS, cycle club etc). There's loads of good articles online as well although about a million different methods and measurements that various people swear by.
On a MTB it doesn't really matter hence why people raise and lower their saddle, adjust forks etc. On a road bike position is vital since you're pretty much stuck with it.
From the sound of it you've got too much weight on your hands if they're the first things to go numb. Use the advice as a guideline, don't go trying to replicate the position that the pros use, you're not a pro! Also, do some stretching, I'll bet that part of it is simply that you're not used to being in such a position for extended periods of time. MTBers are renowned for stopping at every gate and the top and bottom of every hill so you never get used to being in one position and just riding.
Posted : 27/09/2010 1:33 pm
Never had a "proper" road bike before so nothing to compare with. I wondered whether the numb hands was due to too much weight on my hands which was why I raised the bars as much as I could and moved the saddle forwards. Mind you iamsporticus seems to be suggesting the reverse?
I find im comfier on the road bike than the mtb.
A technique I read was put your hands where you would normally on the bars and sit on the saddle in your regular position. Look down on the front wheel.
If the front hub appears below the bars then your bike is too long.
If it appears above trhe bars then its too short.
If its obscured by the bars then its the right length.
Posted : 27/09/2010 1:34 pm
Not to keen on taking my cheap mail order road bike into the local roadie shop for advice, feels a bit too cheeky really. I thought I'd start by asking on here in case there were people who knew about such things. The lack of consensus over methods and measurements seems a bit odd.
Posted : 27/09/2010 1:37 pm
Took me about 2 years to get my road bike sorted. Including several stems, different shaped bars, loads of different saddle angles and STI lever positions. I'm a dab hand with grip tape now, let me tell you.
100mm stem on a large frame like that sounds way too short, maybe you actually need to get a bit longer & lower to stretch out a bit more.
But yeah, well worth getting fitted as at the moment it's clearly not right.
Posted : 27/09/2010 1:38 pm
Hmm I am 5'11 and have a large Planet X SL. Once I dumped the rucksack I have found it surprisinly comfortable. My backside aches after a while but thats about it.
I did a 70mile ride last Saturday and I am doing the Wiggle New Forest 100 this Sunday. I expect it will be a little uncomfortable after that 🙂
thomthumb, who do you recomend for bike fitting in Southampton ?
Bazzer
Ditto for the bike fit.
Failing that, a large dose of Toughen The **** Up should sort you out.
Posted : 27/09/2010 1:39 pm
I still get numb/achey palms after a few weeks of riding a road bike every day. Think it's just one of those things!
Posted : 27/09/2010 1:40 pm
flexibility has a lot to do with it.
imagine you have you bike fitted today and it fits perfectly.
now imagine that everything stays the same but you get tight hamstrings now it doesn't fit.
EDIT; [url= http://www.carltonroadclinic.co.uk/Cycle_Position.html ]carlton road clinic[/url]
It could be hurting because you are weak. Or more politely, the core muscles that support your head, shoulders and back are under developed for the position you are in on the road bike.
Pilates/core exercises plus a few 100 miles in the saddle should sort you out...
Posted : 27/09/2010 1:41 pm
I've found lowering the saddle a bit great for lower back aches. I have it somewhat lower than I'd ever consider it a few years ago, and it's working wonders.
Numb hands = too much weight on them = bars too low...?
Posted : 27/09/2010 1:42 pm
 hels
OK continue to suffer if you want.
I had a bike fitting when I got a new bike to train for endurance road races. 8-10 hour type things. Never had any problems on that bike. It is a Principia and used their patented system, you get measured and they send it all in to the computer boffins who come back with all the right saddle angles etc.
But maybe I was just lucky.
Posted : 27/09/2010 1:44 pm
Not much use when I can't use my hands to change gear, unwrap food or grip the bars.
Don't live anywhere near Southampton.
+1 for a fitting.
Sounds to me like you're too stretched out. As already mentioned numb hands suggests too much weight on the front, I'd try a shorter stem or saddle forwards (but watch you don't affect your pedal stroke) and/or raise the bars (sounds like you tried that).
Stiff neck is because you're lifting your head too much, again remove the peak from your helmet if you didn't already. Raising the bars should help with this. Are you riding on the drops all the time or hoods?
Aching back is possibly saddle position (tilt) but could be down to a bad riding position trying to take the pain away from other areas!
Of course if you're new to road riding then it could just be that your body needs to get used to the new riding position. If you're new to it then I'd go for a few 20ish mile rides and take tools with you. Take plenty of breaks and adjust your position until it feels more comfortable, try to change just one thing at a time.
If you still can't get comfy then think about a fitting, new stem etc.
Alternatively MTFU and get used to it 🙂
Posted : 27/09/2010 1:49 pm
had a road bike 'fitting' - which suggested i ride a 58cm frame, with a 120mm stem.
The thing was an absolute gate, truly massive. i'm 185cm / 6'2". i could barely reach the handlebars. twas horrible. ended up with a 54cm frame and nice 90mm stem, it's very comfy.
anyway, there about 3 different places to put your hands on roadie bike handlebars, you're not trying to spend all day in the 'drops' are you?
edit: bugger, tony's faster than me.
Posted : 27/09/2010 1:50 pm
Hadn't thought of removing my helmet peak - good idea.
Riding on the hoods most of the time. Stem is as high as it will go and flipped up so 6 deg positive rise, saddle is nearly as far forward as it will go.
Sounds like I need to try a fitting. Not sure I'll ever ride road often enough to just adapt naturally.
Posted : 27/09/2010 1:53 pm
s****horpe? 8)
 hels
You ride on the road with a peak on your helmet ?? The horror !! Do the other roadies throw stuff at you ??
Posted : 27/09/2010 1:55 pm
Numb hands is a strange one. The instinctive reaction is to raise the bars but actually what you need to do is train the lower back to support the weight.
Set the bike up on a turbo trainer so it's level and sit there in normal riding clothing and your usual position. Now take your hands off the bars but keep your upper body in the same position using your lower back and core muscles to hold it. Bizarrely it's often easier to do this with a longer and/or lower position...
By the way this assumes that the saddle is already in the correct position...
Something like this:
[img] http://mikesbikes.com/images/library/site/bike_fit1sideview.jp g" target="_blank">http://mikesbikes.com/images/library/site/bike_fit1sideview.jp g"/> &t=1[/img]
Posted : 27/09/2010 1:56 pm
are you not mixing up compact & standard frames there?
Posted : 27/09/2010 1:57 pm
uplink - Member
i haven't the slightest idea what you're talking about, i suggest you ask the shop where i had the fitting.
they wanted me on the 58cm frame - it was the biggest bike i've ever seen. they told me it was perfect. i told them i didn't care, and asked to try one substantially smaller.
Posted : 27/09/2010 2:03 pm
Roll your shoulders & move your head/neck around at regular intervals.
Above it is said that on MTB rides people move around more & stop briefly at intervals. On a road bike you can tend to lock into one position and remembering to move your upper body around a bit every so often makes a huge difference
Posted : 27/09/2010 2:06 pm
Are you sure your 6'2"? You sound like a 5'8" contender to me
Posted : 27/09/2010 2:09 pm
Saddle forward would give you hand pain. Saddle back and lower, bars rotated backwards...?
Btw road bikes are much longer than your MTBs. If you get on one after being used to MTBs it will feel ridiculously long. My road bike is borderline too small (compact 53cm, I'm 5'11) and it still feels unnaturally long after I've been riding the Orange 5 for a while.
Posted : 27/09/2010 2:10 pm
[i]had a road bike 'fitting' - which suggested i ride a 58cm frame, with a 120mm stem.
The thing was an absolute gate, truly massive. i'm 185cm / 6'2". i could barely reach the handlebars. twas horrible. ended up with a 54cm frame and nice 90mm stem, it's very comfy.[/i]
I'm 6'3" and ride a 60cm with a 120 stem (actually one of my road bikes has a 130mm) and it's perfect. Depends on the make as one manufacturers 58cm will be another ones 56cm. From the sounds of things you're still on the wrong size - a 54cm is usually suitable for people about 5'6", just based on the info about your height (and without seeing you) I'd have said 58cm as well.
Posted : 27/09/2010 2:15 pm
+1 - a 54 is something that's only just too big for me, and I'm 5'7"..! Sounds like the shop had it just right.
Posted : 27/09/2010 2:18 pm
Mountain bikers..... 🙄
There is loads of fitting advice available for free on the net, or from your local library, and far more consensus exists regarding road bike fit than for mountain bike fit...
...and that's why bike fitting is considered by some to be a waste; you are paying out for someones opinion plus a series of well documented measurements, plus as noted above; bike fit is a dynamic thing. It changes as you change over time.
Do things in order;
1. Set your saddle height.
Stand against a wall in underpants and socks, push a book up into your crotch as if you were sitting on your bikes top tube, then get someone to measure the distance from the book to the floor.
This is your cycling inseam measurement.
Then multiply this by 0.885.
Then use this figure to set your saddle height FROM THE CENTRE OF THE BB TO the saddle top.
2. Saddle setback.
If you are tall, push the saddle backwards past it's mid point on the seatpost; you can fanny about with this later.
Sort these two things out first, then try to LEAVE THEM ALONE.
3. Put your bars as high as you can; the aim is to get them down as you get used to riding.
4. Stem length; When in the hoods, the front axle should be obscured from view by the handle bars, choose stem length accordingly.
That's about it, apart from tweaking things bit by bit.
You've got sore hands and neck and arms because you have too much weight on your hands, because you have shuffled your saddle forwards to compensate for being weak. Put it back.
Posted : 27/09/2010 2:19 pm
Sounds to me like you're too stretched out. As already mentioned numb hands suggests too much weight on the front, I'd try a shorter stem or saddle [s]forwards[/s] [b]backwards[/b]
If you have too much weight on your hands move the saddle backwards so your arse acts as a counter-balance. Get the saddle position correct first, then find where your hands naturally fall and put your bars there.
See the "Saddle Front/Back Positioning" section on Sheldon [url= http://sheldonbrown.com/frame-sizing.html ]here[/url].
That's what worked for me and for my wife, anyway. There was a better web-page than Sheldon's but I can't remember where, but it gives the general impression.
Posted : 27/09/2010 2:25 pm
the guys in the shop were pretty incredulous aswell, what can i say?
i'm not scared of big bikes - i ride a 20" blue pig. i'm 6'2" and have a 36" inside leg. i've always needed big bikes. my old pro-flex 857 even came with a 'WAAY Big' sticker instead of the usual 'XL'
i've got a Hemlock, i wanted an XL, but Cy only makes a 'L' - so i need a 420mm seat post to get good leg extension.
my specialized allez has a 350mm seatpost - it's not set at the limit, but i get good leg extension when i pedal.
i have to reach a little to get to the hoods, the drops aren't too far away.
it's very comfy.
it's lots of fun.
54cm = 21" (yes, i've measured it)
roadies are weird (a friend of mine has refused to join me on a ride until i turn my 6degree rise stem the 'right way up' (down))
Posted : 27/09/2010 2:29 pm
 Haze
5'7 on a 54cm with a 90mm stem here.
Can't imagine anyone over 6' being comfortable on mine!
Posted : 27/09/2010 2:31 pm
 ton
my roadbike, a surky lht, fitted with flat bars, barends and a brooks saddle, is as comfy as a nice old comfy sofa............ 8)
Posted : 27/09/2010 2:34 pm
That's all well and good crikey, for a standard sizing guide but takes no account for the fact that humans are all different. A good bike fit studio will take into account differences between people in regards to biomechanics, flexibility and riding style.
A prescribed fitting technique will work for the majority but when people have a fit issue this is precisely the time a [u]good[/u] bike fitting consultation will help.
Posted : 27/09/2010 2:37 pm
There's a load of shit spouted on here :o)
Posted : 27/09/2010 2:42 pm
A friend of ours does the Specialized Bike Fit thing (she's a physio) where she looks for any areas that might be causing issues - sometimes a wonky leg might mean a cleat needs moving or a long back might mean a longer stem is needed.
I don't road ride much but my 2010 Allez is really comfy with no hand issues or backache. Something isn't right on yours. Leg burn is fine, aches and pains other than that aren't IMO.
Posted : 27/09/2010 2:47 pm
john_l - Member
Yes there is, but it's good shit and works as a great diversion from exercise - I promised myself a trip to the pool at lunchtime 🙂
Posted : 27/09/2010 2:50 pm
 SiB
Has anyone actually asked if the saddle is still on? Would hurt if it wasn't
Posted : 27/09/2010 2:52 pm
I'd advise a bike fitting too just make sure you tell them what you want - more confort not more "speed".
I'd add that you could add some under the tape gel to you bars since this will add some confort plus go for a 25mm front tyre and only run it at 90-95psi. All these should reduce the harshness of a stiff frame like the planet X.
Although it may just be taking you a while to get use to the new position.
Posted : 27/09/2010 3:24 pm
I'd advise a bike fitting too just make sure you tell them what you want - more comfort not more "speed".
I'd suugest that you could add some under the tape gel to you bars since this will add some comfort plus go for a 25mm front tyre and only run it at 90-95psi. All these should reduce the harshness of a stiff frame like the planet X.
