Road bike speed wob...
[Closed] Road bike speed wobble -help!
[#4180121]
I've got a steel road bike which I love, but it develops a speed wobble when descending over about 35mph. It seems to be initiated by crosswinds or braking. What causes it and what can I do about it? Is it caused by brakes touching one side of the rim before another or using one brake over another? Would changing to OS bars and stem help? Or is it all mental and should I just man up?
Thanks!
Posted : 20/07/2012 11:53 am
Worn headset?
Wobbly wheels?
Posted : 20/07/2012 11:56 am
 Aidy
Shimmy?
Posted : 20/07/2012 11:58 am
[i]what can I do about it[/i]
Try gripping the top tube with your knees and see if that helps.
Posted : 20/07/2012 12:16 pm
And keep the pedals level.
Posted : 20/07/2012 12:20 pm
Have you got you weight balanced? I found that coming from MTB I had a tendency to shift my weight too far back, getting back off the saddle - you need to get a bit more weight over the front on a road bike.
Posted : 20/07/2012 12:21 pm
This?
It's related to harmonic motion iirc. Gripping top tube with knees/hand helps, braking can actually make it worse. It can be quite scary, first time it happened to me I thought the wheels were about to fall off.
Posted : 20/07/2012 12:22 pm
Descending in a crosswind is something I do NOT enjoy. Scares the crap out of me to be honest. I sit up and take it easy rather than get on the drops.
Posted : 20/07/2012 12:31 pm
try changing air pressure in the front a bit.
asides from checking hs/hub bearings
Posted : 20/07/2012 12:37 pm
Thanks for the ideas everyone.
Posted : 21/07/2012 5:51 pm
Slow down a bit? Sometimes it's the most obvious. 😐
Posted : 21/07/2012 5:53 pm
I'm already the slowest downhill!
Posted : 21/07/2012 5:57 pm
Oh, OK. Have a look [url= http://singletrackworld.com/forum/topic/road-bike-speed-wobble-help#post-3998605 ]here[/url] for ideas then. 😛
Posted : 21/07/2012 6:00 pm
