I want to run a 27.5+ Front / 29 Rear.
Frame is 100 forked 29er.
Anyhow with this 26fat fork from on one be suitable?
[url= http://www.on-one.co.uk/i/q/FOOOCFAT/on-one-carbon-fatty-fork ]http://www.on-one.co.uk/i/q/FOOOCFAT/on-one-carbon-fatty-fork[/url]
Or this one?
[url= http://www.on-one.co.uk/i/q/FOOOSCF4709/on-one-monocoque-straight-steerer-carbon-fork ]http://www.on-one.co.uk/i/q/FOOOSCF4709/on-one-monocoque-straight-steerer-carbon-fork[/url]
Axle - to - crown measurement is OK, you'll need to be happy having a 135mm front hub, so you can't use it on regular or boost fork dropouts. Not many stock front wheels with wide 650b+ rim and fatty hub tho.
Ahhh...
The fatty fork is for a fatty hub - got it.
If you want a rigid fork with plenty of clearance for 29 or 27.5 plus try the Surly Krampus fork, about £75 and 483mm a2c measurement. Not light but bags of clearance and normal dropouts. If you want carbon then exotic or on one carbon 29er are at the cheaper end.
