use ridewithgps quite a bit and just downloaded a map from someone random on FB:
shows solid red = sealed
Dashed red - white = gravel
New to me:
?dashed blue - white = ? Section I would expect to be gravel ...
Any ideas ridewithgps help has failed me
What does it show for the section if you plot it yourself? Maybe they have manually changed the colour of that section for some reason.
What bit of track? They may have applied their own colouring system according to data tags on Openstreetmap. If you know where to look then you can look it up there.
Think frogstomp has it...if I plot the section comes out as expected from general knowledge of the area .... red-white dashed...so author has manually changed and when I went to search for route I found another by same guy with all the gravel blue-white so just an oddity of the author I guess but inconsistent
