Reverb post
[Closed] Reverb post
See what I did there? For 1 second I was very pleased with myself, as I am sad like that.
Right, have searched, but to no avail, so can anyone tell me what is the difference between a Reverb MMX 1500 and a normal Reverb MMX?
I am looking to get one to fit that needs to be 30.9, 125 mm drop and button will sit on the right. Wiggle have some at £180 ish. Seems ok* value, but normal MMX is £220 or so. Only difference I can see is the colour of the collar. It is to fit a size L Trance X and would prefer to fit without bleeding, if possible.
Do they have any lateral play in the seat, or do they hold firm?
*obviously compared to other overpriced dropper posts.
Posted : 20/02/2014 1:39 pm
I think 1500 is the hose length in mm
I think someone asked the exact same question last week
The standard hose on mine was far longer than it needed to be, no idea how long it was though.
Posted : 20/02/2014 1:52 pm
The replacement hoses are 2000mm, I guess that would be the standard length.
Posted : 20/02/2014 1:57 pm
Thanks both, will measure up what I think the minimum length needed is. Seemed very cheap to get the one at £180... just checked and everything out of stock, apart from a 100mm drop. Rats.
Posted : 21/02/2014 11:56 am
Think someone linked earlier today for reverbs at £180. Summit to sea was the shop I think.
Posted : 21/02/2014 12:11 pm
Some that are more expensive come with a bleed kit which is really handy if you have a small frame and you need to cut the hose down, also come with some awesome clips that connects the hose to gear/brake lines.
Posted : 21/02/2014 4:38 pm
