Reverb - movement a...
[Closed] Reverb - movement at the top?
Hi All,
Just a quick bit of advice if you can....?
I have had to refit the hose (after breaking the barb off), so I have re-bled the system and checked the air pressure is at 250psi - however, I have a little movement at the top of the travel, i.e. when you sit on the saddle the seat post compresses by about 10mm (ish - maybe a little more?).
I have re-bled and it is still the same, does anyone know what it could be? Any help or advice would be much appreciated.
Thanks.
LT.
Posted : 22/02/2012 12:10 pm
Can anyone in the evening crowd help?
Posted : 22/02/2012 7:20 pm
