Reverb MMX LEft/Rig...
[Closed] Reverb MMX LEft/Right... confused! Please help!
[#4721227]
Ok, basically at the end of things, I want to mount the remote under the bar on the left.
Do I have to buy a standard right clamp and fit it under the left?
Or can I buy one of the MMX versions? If so which 😕
Thanks!
Posted : 06/01/2013 10:29 pm
Mmx allows you to combine the remote with certain SRAM brakes and shifters. Doesn't sound relevant in this case.
Just get a right hand remote, which is normally fitted on the right over the bar and fit to the left hand under the bar. Hope this helps
Posted : 06/01/2013 10:44 pm
Just fitted a Right Hand mmx version under the bars on the left side. Not running a shifter on that side so loads of room and prob didn't need the mmx tbh (what they had in) as removed the bit that attaches to the shifter/brake.
So, buy Right hand side and fit under Left hand side or vice-versa
Hth
Carl
Posted : 06/01/2013 10:45 pm
Mister - It's stock availability that determines this unfortunately 🙁
Carlos - Brilliant! So the MMX version just detaches and you then have a standard clamp? No need for any extra parts?
Thanks
Posted : 06/01/2013 10:47 pm
I've been having a bugger of a time fitting my reverb remote under the bars when combined with 775 XT brakes and 770 XT shifters. Went for the left remote to fit it to the right but they make the remote so bulky that it's hard to fit and get everything in a nice place.
Posted : 06/01/2013 10:48 pm
Yeah, just found this whilst looking to make sure I wasn't typing shite.
See here-
Hob Nob - Member
The MMX mount is the same as the normal one, just with the MMX bit bolted through for if you plan on using it. If you don't want to, you just unbolt it.
The lever mounts are identical.
POSTED 1 YEAR AGO # REPORT-POST
enduro1987 - Member
If it definitely comes with the standard useable clamp then i may aswell get the MMX version as if i ever decide to upgrade to XX brakes in the future i have the matchmaker clamp. If someone who has actually got the MMX version could comment would be so useful
enduro1987 - Member
@Hob Nob thats great thank you
enduro1987 - Member
Reverb came today the MMX adapter compatable but took that off and used clamp as per standard and it fits perfect. So pleased with it! 10 times smoother than the command post! And love the fact you get the bleed kit and tools etc in the box.
Posted : 06/01/2013 10:56 pm
I only have a shift on the right as I use 1 x 10.
Carlos - Thank you, for costing me money in the purchase I'm about to make 😉
Thanks though! 😀
Posted : 06/01/2013 11:02 pm
😆 Your welcome
Posted : 06/01/2013 11:05 pm
