Reverb dropping 10m...
[Closed] Reverb dropping 10mm, advice sort.
[#6152753]
Afternoon all.
I'm having isuues with my reverb which drops 10mm or so when weighted (another one), the question is, is this recognised as a 'known issue' or is it something I'm gonna have to pay for?
The post is an original mk1 but has had little use, it was bought from germany so if possible I'd like to return it to the distributors, whoever they may be?
Posted : 29/04/2014 4:05 pm
 dlr
Check the air pressure with a shock pump, valve is in the bottom, 250 psi or something I think, google...I've had to do this about twice a year
Posted : 29/04/2014 4:08 pm
Take the post out and check the pressure in the main chamber should be 250 psi. They do sometimes lose air.
Yep, it's the pressure. I have to do it every couple of months or so.
Posted : 29/04/2014 4:09 pm
Cheers fellas, pressure was 150, pumped it up to 250 and all is fine now.
Top marks for everyone!
Posted : 29/04/2014 4:19 pm
I had this problem, so I sent it back to bike-components.de. I was just about 4 weeks away from the warranty period ending. Within 3 weeks they'd sent me a new one to replace it. Winner!
Posted : 29/04/2014 4:28 pm
Mine did it after 2nd ride, checked pressure (a faff on a stealth, saddle off job) no change. Bled it no change, back to Fishers for another one much better, got rid!
Posted : 29/04/2014 4:30 pm
@wallop I thought I was going to be getting a mk2 for a minute. Oh well at least its working as it should again. I'll keep an eye on the pressure though, think I got mine from bikediscount.de.
Posted : 29/04/2014 4:35 pm
Hi Mine did that. had the exact same sypmtoms. It had to go back and get replaced on warranty. it was something to do with a seal or other internal gubbins i think. its a worldwide warranty though so if you contact fishers theyll tell you to return it through one of their dealers with the origional receipt(i printed out my payment confirmation off of paypal).
Posted : 29/04/2014 4:48 pm
advice sort
Past tense of seek is spelt sought. Was that the type of advice you were looking for 😉
Posted : 29/04/2014 4:51 pm
 iolo
Lift it 10mm higher in the frame?
Posted : 29/04/2014 4:53 pm
A good way to avoid this happening so frequently, is only leave the post extended when storing the bike. If you leave it compressed down at all for any length of time, it slowly loses pressure.
Posted : 29/04/2014 4:54 pm
This happened to me, was replaced under warranty no-quibble. In the docs somewhere it says to do that.
Posted : 29/04/2014 5:06 pm
And me, got a new one under warranty.
Posted : 29/04/2014 5:14 pm
Mine does this every so often. Unfortunately bought 2nd hand so no warranty. However, I know which O-ring is leaking and it always seems to go every few months. I can strip and replace and have it back to normal in a bout 1/2 an hour these days. And the O-ring costs pennies.
Posted : 29/04/2014 5:18 pm
