I'm wanting to mount an AXS reverb remote to standard MTB handlebars. Either separate clamp mounting to the bars, or direct mount to a Hope Tech 3 lever.
Google is failing me - I keep coming up with seat rail clamps, the old hydro plunge lever, etc. Someone please tell me what to buy!
A mount comes in the box?
Failing that, any sram shifter clamp will work.
Successfully mounted to my nice bike.
But wanting the ability to occasionally drop it into my hardtail without having to take the grips and brake off both bikes each time.
Hope do a Sram mount for Tech 3 levers
Sram do Matchmaker clamps
Not sure if you can link 1 post to 2 remotes, but I have a spare brand new remote if you fancy it. I had a warranty replacement on a whole seat post and they sent me a full boxed item with another remote.
Much less faff than swapping the remote every time.
PM me if you are interested.
I used a Bike Yoke adapter to fit my Reverb AXS remote to my Shimano iSpec EV brake lever mount. I am pretty sure they make one that works for Hope brakes as well. I got mine from TF Tuned, they'll probably be able to help.
I think that would be a bit too much to justify for my limited use case (says the man who has a seatpost that cost more than my first MTB)
Would have to pair them each time I swapped, which wouldn't seem to difficult, but neither does a one bolt connection once I've got the new clamp.
But I will see how it goes.
If anyone finds this thread in the future, the thing to seach for is SRAM shifter clamp - most of the links list every type of compatible geear shifter, and make no mention of the reverb, this is where I was getting stuck
These are great and probas in someones spares box.
https://www.amazon.co.uk/Tbest-Bicycle-Trigger-Aluminum-Shifters/dp/B07FG7TWRQ/
