They're £77 at rrp, off the top of my head as on my phone, we're considerably cheaper than that though 😀
Cheers Loco.
SRAM need to sort out their site and make it clear.
Been as its not all that expensive I may still take the rev route.
Cooie, yes you they cabn be swapped but it's not cheap
Cheers, think I'll give it a miss then 🙂
Stevenk, yes they're 1 1/8" steerers, the damping is more basic than the rlt ti revs, but we can tune them for you.
Can their travel be adjusted with spacers, may be interested in getting a tune for them if they are.
Also, what are the dual flow upgrade possibilities for my RLT Ti's?
No problem boxxer - if you're looking at a TRc, give us a shout too. Just bought one myself, playing around with 140 vs 130 (X Fusion Velvet)
Si
Stevenk, yes the solo air Sektors can be spaced down, reducing the travel and axle to crown, as the system is differnt to the Revelation solo air system.
The RLT Ti Revelations have got a Dual flow rebound assembly in then, but you could upgrade the compression damper wirth an RCT3 unit and re tune the rebound damper. 😀
