Upping the travel o...
[Closed] Upping the travel on Rebas, Poddy?
[#4348176]
Is there a manual showing how to up the travel from 80mm to 100mm on first gen dual air rebas? I think I have to remove a stopper or add a stopper dont I?
Posted : 10/09/2012 3:52 pm
 LoCo
http://www.sram.com/service/rockshox/7,103
Look at the technical manuals for the year or closest year, will have a spacer in the air assmembly that can be remove to increase the travel if possible.
Posted : 10/09/2012 3:56 pm
Not sure if this works for you...
https://docs.google.com/file/d/0B1AoGIWBz4H1M2E5ZTc0MTItNjM4NS00YjBiLWEwZDgtMjEyYTQ5NWZlMjc5/edit
Posted : 10/09/2012 4:05 pm
Thanks LoCo what would you charge to change the oil and up the travel?
Rich
Posted : 10/09/2012 4:06 pm
soma_rich - Member
Rich
Give it a go yourself. It is very straight-forward. If you find that you can't do it you can then send them to Loco.
Posted : 10/09/2012 4:10 pm
Simon that's a cracking guide. I think I can do that. Bit nervous though....
 LoCo
Lower service, so clean of lowers,(replace foam rings) bush check and adjust if necessary would be £20 labour plus postage, if you need new wiper seals that would be extra. 😀
Posted : 10/09/2012 4:11 pm
soma_rich - Member
There's an even easier way to remove the spacers and it doesn't require an oil change. It took me a couple of minutes to do, including getting the tools out. Search the www.
Having said that, Loco does a very good job and 20quid sounds very reasonable.
Posted : 10/09/2012 4:17 pm
You know there is Rich!
Unfortunately I'm away all week now and I don't have access to it until the weekend. 🙁
It's very easy to do. Either do it yourself or wait until you're in my area and I'll show you how it's done. 15min job.
I keep forgetting to run off a CD of your wedding pics too. Arse! 😉
Posted : 10/09/2012 4:20 pm
