Retro road bike, wh...
[Closed] Retro road bike, wheel thread and help needed
One of the lads has an old retro custom built Geoff Butler road bike.
He needs some new wheels for it. Deffo a rear, but a pair may be nice too.
I believe it's 8 speed, shimano cassette type. Obviously rim brakes.
So can we buy a 10 speed pair and fit them with some sort of spacer ? Or do we need an 8 speed specific hub ?
Info appreciated.
Posted : 25/10/2019 4:26 pm
Yes you can 10speed will work fine. You just use a spacer on the 'spoke' side of the freehub. You may not need a spacer as 8 speed is as wide as 9/10 sometimes a little wider, believe it or not.
I have 7 and 8 speed cassettes running on newer 10 speed wheels.
Posted : 25/10/2019 4:30 pm
Ah, that's fantastic news and massively opens up the options.
Posted : 25/10/2019 4:50 pm
No spacer required unless it is an 11spd freehub (and that should come with the spacer anyway)
Posted : 25/10/2019 4:58 pm
we've got plenty of them anyway from previous wheels etc..
Posted : 25/10/2019 5:00 pm
Might be worth a quick check of the hub/frame width.
For HG freehub length 8/9/10s are all the same, 11s is 1.85mm longer, 7s is 4.5mm shorter.
Certain cassettes with rivets/bolts will not seat on a flat spacer, they will need a spacer with slots for the heads.
Posted : 25/10/2019 5:10 pm
Or go 10s, the pull ratio on the mechs in the same, just get a newer shifter (10s friction doesn't really work reliably).
Posted : 25/10/2019 5:11 pm
Well hes got tube mounted shifters so not sure how viable that would be.
Posted : 25/10/2019 5:13 pm
Downtube adaptors allow you to run handlebar mounted gear shifters
Posted : 25/10/2019 8:17 pm
Retro bikes of a certain age have slightly narrower rear hub spacing. 126mm not 130mm IIRC. On a steel frame it has never been an issue. There is enough flex to accommodate.
Posted : 26/10/2019 10:38 am
If its running 8speed then its already 130 or its got enough give.
I'd personally go 11peed hub. Then you can run anything from 8 now to 11 in the future.
I'd also keep the downtube shifters. With 8 speed they're ace. Just a nice way to ride a bike. And you learn really fast to read the road ahead. No desperate last minute changes while out the saddle churning up a hill ๐Ÿ˜€
Posted : 26/10/2019 10:43 am
8 speed is 130mm OLN - as it was when 7 speed became the norm in the mid-80s
Posted : 26/10/2019 10:54 am
As above, a 10speed cassette will fit,
https://www.sjscycles.co.uk/gear-shifters/shimano-duraace-sl7900-10-spd-brazeon-down-tube-shifters/
Those will pull the existing mech and work perfectly.
Edit: i use dura ace 10 speed bar end shifters pulling a 9 speed xt mech over a 10 speed cassette.
Works perfectly.
Posted : 26/10/2019 11:47 am
