replacing wiper sea...
[Closed] replacing wiper seals-Pike
[#9484954]
Getting them out seems easy enough. How hard is getting new ones back in again? do they tend to need the press? are they hand tight, can you tap them in with a soft mallet?
Any experience welcome (before I **** it up) 😆
Posted : 10/08/2017 8:46 am
Firsty don't resort to the mallet. First point of impact will be the feather edge of the seal. I made a mandrel the correct size to push the seals in on my Rev's and 36's. However a suitable size socket or similar will be a good substitute. Do your best to keep them straight, they've got a tendency to try and go in on the piss so take your time. Once you get the seal established in the bore they're not actually that tight.
D.
Posted : 10/08/2017 8:55 am
Unior 35mm seal tool off for a tenner, right tool for the job, worth getting
https://www.amazon.co.uk/d/Sports-Outdoors/Unior-Fork-seal-installation-tool/B01L1RVH7U
Posted : 10/08/2017 8:59 am
I used the old seals to push in the new.
Posted : 10/08/2017 9:00 am
i used my thumb. They went in fine with a little lube.
Posted : 10/08/2017 9:11 am
Are you on the correct forum Andy?
Posted : 10/08/2017 9:14 am
I also thumbed mine in, after a bit of spit one the rim.
Seriously, though. They went in no bother last time (a week ago) and they were from a full pike service kit. Time before that was harder (seals only). Sourced from TFT.
Posted : 10/08/2017 10:09 am
Old PF 30 BB is perfect for the job
Posted : 10/08/2017 10:13 am
Thumb it in. I put them in the freezer first
Posted : 10/08/2017 10:18 am
suitable diameter bit of plastic pipe
Posted : 10/08/2017 11:18 am
