Replacing bent seat...
[Closed] Replacing bent seat rails on SDG Bel air?
Can this be done?
I have bent mine but got an old Bel Air saddle with good rails. Hoping its just a case of undoing screws underneath and a straight swap or are they pressed in at the factory ?
Posted : 08/08/2012 10:36 am
Have exactly the same scenario so interested in this too ๐Ÿ™‚
Posted : 08/08/2012 10:38 am
try it - any time I've seen rails pop from a saddle they either don't go back, or keep poping out if they do.
Don't know this saddle tho.
Posted : 08/08/2012 10:39 am
I have tried this. Unsuccessfully. Wear eye protection would be my tip.
The rails need to be 'flexed' to pop them in. You'll need six arms to apply enough pressure AND hold everything in place.
Posted : 08/08/2012 11:01 am
out of interest what rails got bent solid ti, hollow ti alloy, cro mo?
Posted : 08/08/2012 11:03 am
Tried a while ago to swap the rails on a Charge Spoon and as above the rails needed to be flexed (a lot) when re-inserting them
Good luck
Posted : 08/08/2012 11:04 am
I bent some CroMo ones. Sounds like it's a lot of effort, might consign mine to the bin ๐Ÿ™
Posted : 08/08/2012 11:11 am
Bent cro-mo ones by bike bouncing down an Alp. Got Ti ones to put in, maybe a bit easier to flex hopefully.
Posted : 08/08/2012 11:14 am
