REPLACING AVID JUIC...
[Closed] REPLACING AVID JUICY CABLE HOSE
[#2439751]
I need to replace my cable hose on my front Juicy 5. Has anyone else done this? Is it easy? Will a metre length of standard Goodridge cable hosing for 8quid off CRC do th trick? My LBS reckoned they didn't have the right hosing in stock but surely it's all pretty standard?
Posted : 05/02/2011 5:37 pm
Use a Clarks's kit from CRC, you wil get the right connectors when you buy.
And if you want Goodridge -
You will need a avid/goodridge kit, and they cost a bit more than 8 pounds.
Posted : 05/02/2011 6:20 pm
Ta Terry. May as well buy a replacement brake as the Clark's is £25. Add an hour's labour and a replacement Juicy 5 will cost the same.
Posted : 06/02/2011 1:28 pm
