Replacement Camelba...
[Closed] Replacement Camelbak parts??? buckle/clasp any ideas
has anyone got any idea where I can get a replacement buckle for my camelback?
pref genuine though I cant find anything to suggest you can buy them? its the prongy (LOL) part of the buckle that I could do with replacing
any ideas?
Posted : 25/10/2017 1:03 pm
Can't help with genuine but its just a case of finding your size...
https://www.amazon.co.uk/Prym-Clip-Plastic-Buckles-Black/dp/B00426L9DU
Posted : 25/10/2017 1:10 pm
ah thanks man, appreciated, ill have to first check you can actually remove the original one, hopefully its not sewn in 🙁
must be genuine parts out there surely?
Posted : 25/10/2017 1:12 pm
Nowt listed on the ZyroFisher b2b website.
Posted : 25/10/2017 1:13 pm
Posted : 25/10/2017 1:17 pm
Is there not a lifetime warranty? When the bladder in mine leaked I just brought it to Halfords and they replaced it.
Posted : 25/10/2017 1:20 pm
Most (decent) outdoor kit shops will have similar replacement buckles/clips on the shelf in various sizes for a couple of quid. As might your local haberdashery if you ask, they might even do the replacement for you for not a lot of £.
However you're pretty much always going to have to get the sewing needle out to replace a buckle, but often one side is sewn on the other is just strap-looped. But sometimes where the end is folded and sewn it won't fit back through so again, get your needle out...
I thought as much amedias ref the sewing....I think it is folded and sewn down from memory, I don't think its a buckle that just slides on or off per se...
well guess if I can just find the right size one for it, then I can get my mum sort out the stitching side of it if need be
cheers for the help
Posted : 25/10/2017 1:25 pm
As someone mentioned above. Contact your LBS and they should be able to sort a warranty claim out for you. Camelbak are very good at that sort of thing
Posted : 25/10/2017 1:53 pm
