At over £15 each for Hope bottom bracket bearings (which I believe are a bespoke size so not available from usual cheap bearing supply channels) I could get 3 brand new XT level bottom brackets (or save 2/3rds)
It's the 'spare' bike but it's not going anywhere soon, 'bling' isn't as important on it anymore like it once was
The Hope bearings do last but not sure they last 3x the level of others when not used that often anyway
Which to go for?
Live on the wild side and flip a coin?
What is your time changing them worth to you? How much do you care about throwing stuff away?
Same time to swop a whole BB than bearings
The bearings would get thrown away either option
I get a really long life from my Hope BB's so I'd go with swapping the bearings.
Missing the point! I've found Hope BB bearings last ages (over 4000 miles in all weathers on my hardtail and still fine). I'd expect to have to change a Shimano BB a few times by the time the Hope goes, so that's extra servicing time. The last Shimano BB (SLX) I had managed about 500 miles of the same riding.
Each time you replace a BB you're throwing stuff away. If you replace the cups too then you're throwing more stuff away.
Same questions again?
Gusset EXT24.
Hope bb bearings are 24377 iirc... wychbearings.co.uk are who i use And are about £5each
I find that if you use the shimano BB all the time they last. It's when it sits and rusts in place so if it's on a 2nd bike I'd go hope.
I've got ceramic bearings on mine. From time to time I pop them out, degrease them and add a bit of grease and put them back. Done around 6 years on my main bike and well over 10000 miles.
The only problem I have is the plastic seal covers seem to loose their tight fit but they are only a couple of quid from my lbs.
Also make sure you don't over tighten it. They are not designed to have a side load.
Apologies if you've checked this already, but are you sure that the bearings have really gone. I thought the ones on my Hope BB were shot (even bought some new ones and the tool to fit them). Then I saw the Hope video about cleaning out the crap that can get under the seal. Turns out this was all that was needed
[url=
It would be lucky of it got ridden 500 miles in the next 2/3 years, it's not my every day go to bike
I think I can live with throwing away a couple of BB cups once every 2/3 years
Gone XT
Anyone want to buy a Hope BB, with slightly worn bearings? 🙂
I had one of those gusset BB's in June last year, after hearing good things on here. Went to change the bearings last week only to find the top hat had eaten itself and separated at the shoulder. Not covered under warranty. So gone back to shimano. Cost me £21 for two.
The gusset was good, whilst it worked.
I might. Is there play or just roughness?
Just rough Steve, will strip it down this week and let you know
Depends whether the hope [b]really[/b] does last 3x as long.
If you have to change the bearings, albeit leave cups in place could well be as much faff.
Personally I hate maintenance- find it really stressful and worry about busting stuff because cack-handed.
Anything like the nightmare I've had with my BB the past 36 hours makes me think better to pony-up for fit and forget when truly fit and forget.
I can see the plain steel ones for that price, but aren't the Hope ones stainless?
Not aimed at anyone in particular, but there seems to be a disconnect between people buying Hope BBs because they last longer than most, and complaints that the replacement bearings are expensive. The two things might be linked...
I bought mine because it was red 😉
Can you really buy an XT level BB for a tenner these days ?
Yep CRC
Or Merlin or Ribble
All £10.50
I faced the same dilemma and bought a second hand CK bottom bracket instead. That was 2 years ago.
