Removing white writ...
[Closed] Removing white writing from carbon spacers
[#1226012]
Just got some M Part 1.5 inch carbon spacers. Nice apart from the white lettering spoiling the look of things. I would prefer just plain carbon. Anybody had any luck removing the white writing? I tried the usual suspects (surgical alcohol and nail polish remover) but no effect. The writing is outside the clear lacquer but I just can't rub it off.
Posted : 15/01/2010 9:43 pm
I removed some similar writing recently with a quick wipe of Nitromorse (sic) and then straight into water to wash it off.
Worked a treat for me and didn't harm the lacquer
Posted : 15/01/2010 9:46 pm
I've used brasso.. did the job nicely!
Posted : 15/01/2010 9:50 pm
Car polish shouldn't be too aggressive on the laquer.
Posted : 15/01/2010 10:09 pm
yup, T cut or similar. Or even, toothpaste (although, it may take some time...)
any mild abrasive is fine.
Posted : 15/01/2010 10:24 pm
Perfect, thanks chaps! T Cut and a bit elbow grease did the trick! Much more pleasing on the eye now.
Posted : 15/01/2010 10:33 pm
I have the same spacers and the same problem, but I just used a black marker and inked over the white text. Not perfect but it does the job unless you look closely.
Posted : 15/01/2010 11:22 pm
