Can I remove the motion control damper on my reba's (2010 dual air) without a full strip down (not removing lowers etc.).
Slightly under filled the oil in the damper (should have 123ml, got about 110ml when I rebuilt them). Can I just open it up and top it up now I've got a new bottle of oil? Only been ridden two rides since rebuild hence not wanting to fully strip them if not needed.
Simple answer - yes! Just unscrew the top and stick some more oil in.
Oh and I ended up with about 115 ml in mine. If i put in the amount in the service manual, I found I did not quite get full travel. Have about 2mm vertical movement before Lockout so just about right.
Yep, as said, just undo RH leg. No need to even take the air out.
Great, thank you everyone ๐
