Do all tubeless valves have these? how do you remove them?
What happens if you try to remove non-removable ones?
Just found out the answer to the second part - the core breaks
Rest of the question a bit irrelevant now, now where can I buy a new valve..... Any recommendations?
I love the way you waited a whole 13 minutes for an answer to your question before trying it out for yourself. It is this sort of spirit of inquisitiveness which makes Britain Great 😆
[url= http://lmgtfy.com/?q=tubeless+valve ]Let me Google that for you...[/url] 😛
Andy
LOL...
[url= http://www.nextdaytyres.com/Tubes/Stans/No-Tubes-Accessories.aspx?ID=13801 ]Try here[/url] you can buy valve core removers..er obviously you need a valve which has a removable core!
Cheers guys.
I guess the real question was which of my local bike shops will have a valve in stock tomorrow morning.....
you near southampton ?
if you can get to the general between 9 and 12 tomorrow I'll give you one 😳 if you'll send a donation to stw
(presta - 2 shapes to choose from, each with a genuinely removable (and replaceable!) valve)
Core removal tool = spoke key 🙂
Or find an old inner tube with a removable cored valve and cut it out with some scissors. Schwalbe tubes usually come with removable cores.
Thanks scardypants I appreciate the offer, but cost of fuel probably makes it a bad move. Also I would miss my pass to go for a ride
if your looking for tubeless valves i find the specialized valves designed for their tubeless roval wheels are about the cheapest and fit most rims with a presta size hole.
Worth noting these do not have removable cores.
http://www.leisurewheels.co.uk/products.php?plid=m2b3s119p5728&rs=gb
