Remedy 29er Sizing ...
[Closed] Remedy 29er Sizing / Info
[#8161439]
Looking for a bit of feedback on Remedy 29er sizing.
At 6ft I'm assuming that I'm looking at the 19.5" frame? The reach looks correct in terms of current bike.
Also anyone happen to know if you can run an angle set / offset bushings to lower / slacken things if running 150mm / 160mm fork.
Cheers for the help.
Posted : 15/11/2016 10:19 am
I would think 19.5" would be right - I am 6'2" and run the 21.5 on the bouncy Trek and 19.5" on my old 29er Stache. I went bigger on the new one just to give a bit more length to be honest!
Depends where your height is, and how you like to ride! You would probably be okay on either!
Posted : 15/11/2016 11:20 am
I'm 6ft 1inch and inbetween sizes which is annoying with Trek, so far I've opted for a 21.5 on Trek for the reach but think you might be better on the 19.5. You need to try one really.
Posted : 15/11/2016 2:14 pm
5'11 and riding a 19.5". 50mm stem
Offset bushing in the bottom end of the shock plus 160mm forks
Angleset won't fit as headset is integrated.
Fantastic bike.
Posted : 15/11/2016 4:27 pm
