Recon PSI mystery
[Closed] Recon PSI mystery
Hello, I have to Recon Silver's that needed some TLC which they got but they still have an issue where I can pump them up way above the psi for my weight (80kg = 100psi) and they don't feel any noticeably harder. I've got them at 200psi now.
Anybody got any ideas?
Posted : 03/02/2014 11:16 pm
Any one???
Posted : 04/02/2014 7:36 am
Do you need them harder? If not, why do it.....?
Do they leak? If you check the pressure after a couple of weeks, has it dropped much?
How old are they? Ever been serviced?
TBH there's very little to go wrong in a recon silver! ๐Ÿ™‚
Posted : 04/02/2014 7:43 am
Does your shock pump work right?
Posted : 04/02/2014 7:50 am
Sounds to me like you've got a blockage or bad connection on the schrader valve on the fork so when you pump you're just pressurising the pipe on the shock pump
Posted : 04/02/2014 8:01 am
It started by me playing about with something that wasn't broken...
I have just serviced them: new seals and oil with a full clean of all the internals- no sign of obvious damage. And yes PeterPoddy there isn't much too them!
The shock pump is a candidate which I can't rule out yet as I haven't got a spare.
And my mate at work has given me some spare valve cores which are going in once my boss leaves the office!
Posted : 04/02/2014 8:48 am
A new valve core seems to of sorted it out; not sure what was wrong with the old one but it clearly wasn't working properly
Posted : 04/02/2014 10:05 am
how many pumps does it take to pressure up?
if its only a few then it may be your pump (doesn't take much to fill that little hose)
Posted : 04/02/2014 10:14 am
No, definitely the valve core as; the pumping was a lot 'stiffer' before but not it pumps up in a more regular fashion (if that makes sense!?).
And I fully recommend servicing forks as they feel supper smooth now!
Posted : 04/02/2014 10:29 am
