HI basically looking for a 100mm hardtail 29er frame with 71 ish head angle must have rack fender and two bottle mounts and preferably alu any ideas ?
https://www.orangebikes.co.uk/bikes/clockwork-100
Check out http://www.jejamescycles.co.uk/orangemountainbikes-p1.html as they're selling off 2015 models for £750/£1000
looking for frame only something similar to a scandal but not a steel as I want to keep the weight down everything seams to be getting slack and tall which wont suit the flat area I am moving to.
Clockwork has only one set of bottle mounts and no rack mounts on the seatstays and is bloody long in the top tube at a shade under 5'8" i think its to long with a 620 mm toptube.
Shame Spesh dropped the rack mounts when they changed the Carve to the Crave. Ticked the box until then. My son has a Carve which used to be mine. Great bike.
Your looking at the 2016 geometry, the 2015 is shorter @ 608mm ETT on a medium (its not as "long" as the stem is shorter) & does have rack mounts on seatstays, maybe only one bottle mount though.
Good luck with your search.
Anyone know the HA for a parkwood? It's designed around a 120mm fork so 100mm should steepen it by a degree or so... Right?
Interesting idea with the Parkwood off to the onone site for a peek
no mounts on the parkwood 🙁
