I've been riding my Orange Crush for about 6 weeks (not continuously) and have managed to bend the rear wheel rim. To be fair they're not a tough rim by any stretch (Mavic XM117) and I'm quite a heavy rider at just over 16st.
Any ideas for a sub £100 replacement rear wheel that has a tough-ish rim and a disc hub (preferably Shimano 525)?
Thanks in advance.
DS
mavic 721 rims are pretty tough
leave the rear hub as is and get your LBS to rebuild it onto a different rim?
I run 729s or 321s depending on the bike. the former is stronger
how about a wheel with more spokes? say 36 lots of strength in the build and the spokes
721's are a bit lighter than the 729 i think, plus they are a bit narrower aswell so if you dont run wide dh tires, they may be the better choice.
my mate just got a set halo sas wheels 48 spokes on the back wheel not chance of breaking that 1 😀
would have said a 721, any hub. built with good quality spokes (these effect the strength more than other components) and built by a good well respected builder. wheelpro/ merlin spring to mind.
reversed the car over a 729 once, hub was well n truly knacked but the rim was still true, and still goes well ffatre rebuilding it on a new hub on my singlespeed today.
721 survives on the back of the tandem Ok Lasts a couple of thousand miles
As above 721s are very tough I am hard on rims but these are holding up really well. That or I am getting soft!
Halo SAS - 48 spokes of awesomeness. I've a rear on my hardtail and it gets loads of abuse and is still in perfect working order. A pal also got a set cause he's a big lump and his are still going strong too. A tad heavy if you're that way inclined (i.e. gay)
EN521's I've been running the same set of 521's for over ten years now.
Replaced my xm317's with en521's on my five, much better, take a beating and still true (as much thanks go to a good wheel builder as to the rim though)
Got an EN521 on the back of mine, still going strong with no attention required for 1 year. The extra width helps a lot too.
My 729's have proved to be very tough.
Not even a wobble in them after 1 DH alps trip, 1 singletrack type alps trip, lots of time spent on the hard tail in the peaks, N wales, Scotland and the lakes. I'm 17 stone and not gentle.
EX729's are bomb proof. I used a pair laced to hope hubs for a few years. Was ready to build another set but moved to tubeless and never got around to it.
I have two grey 729 rims for sale. One unused and the other built then unbuilt but never ridden.
Soafaking, WTF is that? A motorcycle rim??
If you want to go truly bombpfroof the Exal SP19/Rigida Sputnik is a good choice. Within touring regarded as one of the strongest rims, stronger than Mavics even. Very, very heavy though...
