Recommend me a chai...
[Closed] Recommend me a chain set
[#4329784]
Looking for a new chain set that I am going to run 1x9. I need light as possible but my budget is around £80. Crc have got an slx triple set for £90 which seems good. They don't seem to sell them with just one ring so will have to sell on the rings I don't need. It will be running with a SRAM x7 rear mech and shimano cassette.
Can anyone recommend me one or have they got one for sale? Need it be as good as new unmarked if possible.
Posted : 04/09/2012 11:53 am
Hard to beat SLX, especially at that price. Great cranks.
Posted : 04/09/2012 11:58 am
SLX or even Deore for £55 maybe.
That £90 SLX one has 36t chainring mind so if you want anything lower factor in replacement costs.
Light as possible and £80 sadly don't mix very well in MTB cranks!
Posted : 04/09/2012 12:29 pm
Light, great condition and £80 or less? Easy 🙄
SLX is your best bet new. May get some second hand XTRs or sommat, but doubt they'll be in good nick for that budget.
Posted : 04/09/2012 12:32 pm
+1 SLX
Posted : 04/09/2012 12:36 pm
SLX makes most sense IMO but deore is good too (SLX comes with a bottom bracket that's a fair bit better, deore BB is in the category "good enough, just")
If it's a 36-tooth SLX, I'd be interested to buy the middle ring off you 😉
Posted : 04/09/2012 12:39 pm
It says on crc that it's a 32 tooth middle ring aith the triple set, its a 36 on the double. Not sure which is best for me really with going 1x9.
Posted : 04/09/2012 12:44 pm
The double version has pedal inserts, the triple threads directly into the arm... So in theory the double should be stronger/more durable, certainly harder to crossthread. In practice, not sure if it matters
Posted : 04/09/2012 12:54 pm
the 36 will be ramped so no sue for a 1x9 setup
Posted : 04/09/2012 1:10 pm
I ripped the threads out of the non-drive side without the thread insert, admittedly I was riding with wide flats, but I rarely break stuff. you have to watch for overtightening the pedals with Shimano cranks.
Posted : 04/09/2012 1:20 pm
Loving my Middleburn chainset here, no external BB's to replace every few months, just a buttery smooth square taper BB that's been in the bike for nearly 18 months with no signs of giving up
take your retro BB somewhere else grandad 🙂
Posted : 04/09/2012 1:22 pm
http://www.chainreactioncycles.com/Models.aspx?ModelID=82922
This Raceface singlespeed crank might be worth a look.
Posted : 04/09/2012 1:23 pm
What is it with people and external BBs?
Ive been running an XT one for at least 2 years in several different frames, and its still fine.
Posted : 04/09/2012 1:28 pm
That looks good mackem. Would I be able to run that with a 9 speed rear mech? Also would I need a chain device with that?
Posted : 04/09/2012 1:31 pm
Mech shouldnt be an issue, just make sure you use a 9 speed chain. Chain device? Again dunno, I never use one and have no problems (but I use an Alfine hub). BTW I dont have one of these cranks, was just considering it for myself.
Posted : 04/09/2012 1:33 pm
I know I'm being a bit thick here but what's the difference between an external and internal bb? I've got a shimano zee bb fitted, would I need to change it?
Posted : 04/09/2012 1:38 pm
Zee is an external, as is SLX. Old-school BBs like square taper, octalink etc are internal.
Posted : 04/09/2012 1:45 pm
