Reccomend me some d...
[Closed] Reccomend me some drop bar levers for cable discs.
[#1403136]
Hiya
Can anyone reccomend me some drop bar levers that'll work cable discs? Don't need to be STI as it's for a ss, just brake levers I'm after.
Stuart
Posted : 11/03/2010 4:22 pm
If it's cable discs from an MTB, they are designed to have the same amount of cable pull as V brakes. Only a couple of drop bar levers do this, Tektro RL-520 or Dia-Compe 287V do the trick though. Avid and Shimano both do cable pull calipers to suit ordinary road levers now though.
Posted : 11/03/2010 4:34 pm
depends on what discs you're using. Most are linear pull, so you need v-brake compatible levers then I would choose the Dia Compe levers, [url= http://www.charliethebikemonger.com/userimages/procart18.htm ]charlie sells them[/url] I have a set on my roadrat pulling BB7s. Cane creek make a set aswell and shimano have some too, but availability is usually the issue
if you have "road pull" cable discs (BB7R) then I'd just gets some shimano 105 levers or similar
if you still have to buy the calipers, then I'd go for BB7Rs and get normal dropbar levers
Posted : 11/03/2010 4:39 pm
Cheers fellas, I knew Dia Compe did them but could remember which they were.
Stuart
Posted : 11/03/2010 5:53 pm
<cough> I'm selling some unused Tektro RL520 Drop V levers. Have emailed you the details
Posted : 11/03/2010 6:31 pm
 OCB
[url= http://www.canecreek.com/component-other?product=drop-v ]Cane Creek Drop-V[/url]levers.
Mine pull up the BB7's on the Peregrine, and the BB7/Avid V on the Pompino (when it's on drops), and do so very well.
Incidental: I use an inline set of Cane Creek cross-top levers with/on both sets too, (for the choice - although if you need to haul up fast, the Drop-V's have 10x the power).
Posted : 11/03/2010 9:28 pm
