Just got a 2009 Reba Team 120mm
Fork sticker suggests pos and neg pressures of 135 psi for me at 14 stone kitted up
Early rides suggest these may be a bit high as I'm only getting thru about half the travel
What pressures are you running?
I'm 12.5 kitted up and run them on the lower end of the recommended range.
I'm 11.5 all up sopping wet and run mine at 95psi, still not getting full travel unless it's a truly big hit
i'm 10.5 stone & run 125 pos, & 90 neg.
On the bike I'm around 12.5(ish). I'm running 75+ & 55- at the minute.
13stone, still playing with pressures but 130+/- seems good. Doesn't really match up with what everyone else has posted though!!
Download the manual for refs and play around with what suits your riding style.
14st and run mine and afdter a lot of experimenting run mine at 120.
I'm about 10.5 stone with kit and have mine at 90+ and 85-. I find I need the rebound set almost as fast as it will go too.
Mine took a good bit of experimenting with the pressures but it's well worth it, small changes seemed to make a big difference. At least I don't think it was only in my head.
Thanks all
I'm 14 stone.
Running 110psi in both chambers
gets me 25% sag
I'm 14.5 stone and run 130 pos and 110 neg, i find this minimises brake dive a bit, i hate brake dive.
