Reba 80 to 100mm tr...
[Closed] Reba 80 to 100mm travel adjust...DIY?
2008 Reba Team (NON U-TURN) currently at 80mm
Want to change to 100mm.
Should I do it myself or send to Service centre?
Posted : 29/08/2009 6:07 pm
I did mine myself.Its actually quite straightforward.
Posted : 29/08/2009 6:47 pm
Me too. Bit fiddly if you're scared of stripping forks, but otherwise pretty simple. You'll probably need some fork oil on standby in case you lose some in the dismantling. From memory, you'll need some 10wt for damping and 5wt for lubing - but you'd best check the manual. Depending on how old your forks are, if you remove all of the plastic C-clips you'll be able to increase them to 115mm or 120mm travel.
Posted : 29/08/2009 6:55 pm
