I've just replaced my old Hope XC hub with a pro II evo (both QR).
I've noticed on the new evo that the axel appears shorter as there is a small 10mm gap between the frame and the inside of the hub.
Is this normal?
Posted : 05/08/2011 4:58 pm
Should both be 135 Shirley?
Posted : 05/08/2011 5:13 pm
a 10mm gap is huge.
10mm is nonsense. It's more like 1-2mm
Frame is 135mm and hub is also meant to be however there is a small 1-2mm gap which results in the frame being pulled in
Posted : 05/08/2011 5:15 pm
Just measured the frame spacing and its 137mm, hence why the 2mm gap.
Its a 4 year old stiffee.
Is it allright just to pull the frame in with the new wheel
Posted : 05/08/2011 5:51 pm
