Rear shock spring q...
[Closed] Rear shock spring query
[#2271903]
Need to put a heavier spring on my Patriot and wondered if I could get away with put a 500 x 2.25 on instead of the 450 x 2.0? Would I get away with the extra .25 or should I just stick with the 2.0?
It is on a 190mm e2e Manitou 3 way Swinger if that helps?
Don't really want to buy something and then find out it is no use
Posted : 10/12/2010 3:01 pm
Yep that'll be fine, providing you have enough room for the length
Posted : 10/12/2010 3:03 pm
I have one of those in my shed going spare. If you like I'll check this evening. I guess about £20 posted?
Email me at dan dot enticknap at tiscali dot co dot uk
PS it's a fox spring so I'll get the ID for you as well.
Posted : 10/12/2010 3:09 pm
